66/67 Belvedere help #131904
10/04/08 10:03 AM
10/04/08 10:03 AM
Sierra Vista, Arizona
E
extranjero Offline OP
E
Can you guys post some pictures on how your power steering pressure line is routed and mounted on your small block Belvedere, GTX, or Satellite's? The current set-up I have leaves the hose flopping on the steering column causing it to rub. Thanks in advance.
Re: 66/67 Belvedere help [Re: extranjero] #131905
10/07/08 01:44 AM
10/07/08 01:44 AM
E
E
Am I the only one that owns one of these cars? I know you guys or gals are out there. I mean C'mon, they guy that posted about a small block distributor cap has 23 responses. Post those pictures up, winter isn't here yet! I need to get this turd to the shop to have it measured for a snow plow E-dapter kit.
Re: 66/67 Belvedere help [Re: extranjero] #131906
10/07/08 01:55 AM
10/07/08 01:55 AM
santa rosa,ca
RTDude Offline
RTDude  Offline
santa rosa,ca
This is the best one I have right now
PM me Wednesday & I'll get you some better ones.
Re: 66/67 Belvedere help [Re: RTDude] #131907
10/07/08 02:06 AM
10/07/08 02:06 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Only 2 I have of a small block handy
Re: 66/67 Belvedere help [Re: ScottSmith_Harms] #131908
10/07/08 02:07 AM
10/07/08 02:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 66/67 Belvedere help [Re: ScottSmith_Harms] #131909
10/08/08 06:24 PM
10/08/08 06:24 PM
santa rosa,ca
RTDude Offline
RTDude  Offline
santa rosa,ca
Hope it helps
Re: 66/67 Belvedere help [Re: RTDude] #131910
10/08/08 11:47 PM
10/08/08 11:47 PM
E
E
Oh man! Just what the doctor ordered! Thank you much guys. RTdude, I see your line hooks into the front side of the pump. Mine hooks into the rear. Two different pump styles? This line is a PIA, why is it sooooo frick'in huuuuge.
