Re: infinity sound system ????'s
[Re: reflections7]
#131897
10/08/08 01:49 PM
10/08/08 01:49 PM
DaytonaTurbo
Manitoba, Canada
My infinity system sent only certain freq to each speaker. The speakers had 4 wires. two for the bass and two for high. Also had one in a intrepid that sent two wires to the lower door speaker and two to the upper small speaker. Now my Durango has the same type thing.
What I am getting at is normal speakers sounded terrible when I tried to change them. So be careful trying this.
Are you sure? I know the speakers have 4 wires, but I think 2 are for the speaker signal and 2 are to power the amp on each speaker. I don't think they use seperate wires for high and low sounds, because if memory serves, the infinity radios will plug right into a non-infinity radio connector and work just fine. Sound quality is worse because the infinity speakers are better, but as far as I know there are not seperate wires for high/low frequency sound??
