Leaf Spring rebuild kit? #1318841
10/11/12 01:42 PM
10/11/12 01:42 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Straps, interliners etc? Who has them.??...other then YO ( $70....)
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Leaf Spring rebuild kit? [Re: JMCFAN] #1318842
10/11/12 01:50 PM
10/11/12 01:50 PM
Im interested also. I have a pair that I need to redo since my Mopar Perf ones sagged on me big time!
Re: Leaf Spring rebuild kit? [Re: ] #1318843
10/11/12 01:54 PM
10/11/12 01:54 PM
california
Mr D21 Offline
Mr D21  Offline
california
The rebuild kits will not fix sagging springs...
Re: Leaf Spring rebuild kit? [Re: Mr D21] #1318844
10/11/12 02:11 PM
10/11/12 02:11 PM
VA
VPofGreen Offline
VPofGreen  Offline
VA
Frank Badalson sells them.... from his catalog:
Rear leaf spring rebuild kits. ORIGINAL zinc interliners, band clamps with rubber inserts and plastic interliners.One kit does both springs for A, B or E-bodies. Please note our kit comes with the center leaf spring stack bolt. All parts available separately.
Complete Rebuild Kit………specify body style…………………………. $ 165.00
Re: Leaf Spring rebuild kit? [Re: VPofGreen] #1318845
10/11/12 02:20 PM
10/11/12 02:20 PM
New Mexico
New Mexico
Wow.... from YO catalog
Kit includes correct metal straps with rubber insulators, plastic interliners and zinc interliners. Kit rebuilds both left and right rear springs.
$69
Re: Leaf Spring rebuild kit? [Re: VPofGreen] #1318846
10/11/12 02:27 PM
10/11/12 02:27 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Got mine from BRE.
Re: Leaf Spring rebuild kit? [Re: Mr D21] #1318847
10/11/12 04:27 PM
10/11/12 04:27 PM
I know. I was able to obtain a pair of originals and would like to get the kit to restore them over the winter.
Re: Leaf Spring rebuild kit? [Re: ] #1318848
10/11/12 04:33 PM
10/11/12 04:33 PM
New Mexico
New Mexico
YO and BRE prices are close....lets see what shipping is...in my expeirence...a 20% deal at YO MIGHT cover the shipping....
Re: Leaf Spring rebuild kit? [Re: JMCFAN] #1318849
10/12/12 08:36 PM
10/12/12 08:36 PM
New Mexico
New Mexico
Well I got one apart and ready for cleanup etc... the center bolt on the other will not budge....it I end up having to cut it off... availabel?
Re: Leaf Spring rebuild kit? [Re: JMCFAN] #1318850
10/13/12 12:27 AM
10/13/12 12:27 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
I am wondering about rebuilding the ones I have on the car. I am wondering about the finish. I read an informative discussion here on people recommending what finish. I heard several opinions. What about powdercoating the leaf springs? Do the leaf springs flex too much for powdercoating to stick? Cannot anyone link that topic where people showed what they use to coat the real leaf springs with??
Re: Leaf Spring rebuild kit? [Re: gomangoRTSE] #1318851
10/13/12 01:03 AM
10/13/12 01:03 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If natural steel you can soak them in Evaporust (use a length of PVC pipe as small as they will fit into, cap both ends, fill with Evaporust, soak a couple days to remove all the rust). Once the rust is gone remove them and rinse them with laquer thinner (not water). After dry add back any inspection paint daubs you find then coat each one with RPM (ECS sells it) and reassemble them...You'll be good to go!
Most spring sets that were painted black were painted as a completed assembly so it's easy, just derust/clean them then bomb them with a dull gloss epoxy paint. Adding it until it's almost dripping off will give you a factory look, most look as though they were actually dipped in paint at the factory.
Re: Leaf Spring rebuild kit? [Re: ScottSmith_Harms] #1318852
10/14/12 12:37 PM
10/14/12 12:37 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Scott how would one know if the springs should be natural or painted? i.e. what years and body styles had natural and what ones were painted.
Re: Leaf Spring rebuild kit? [Re: 340cpe] #1318853
10/14/12 12:39 PM
10/14/12 12:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't say that either way is written in stone, there seems to be some variable on whether they were painted or not depending on the year, body style, and even the plant they came from. The best way to know for sure is to carefully study your originals for signs of paint.
Re: Leaf Spring rebuild kit? [Re: ScottSmith_Harms] #1318854
10/14/12 12:56 PM
10/14/12 12:56 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Thats the problem everything seemed to spray bombed at one time. I guess probably the next best thing I can do is when I remove them is to see what they look like under the rear end housing spring perches. Thanks Scott
Re: Leaf Spring rebuild kit? [Re: 340cpe] #1318855
10/14/12 01:11 PM
10/14/12 01:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, that's all true. I'm doing my Los Angeles built 71 Dusters springs now, problem is that all of the survivors I've seen were Hamtramck cars (which were all painted black). My cars originals were missing so no good for reference, other original LA cars I've seen appeared to have natural springs but so far none of them were 71 Dusters so I can't be 100% sure yet. So, I'm going to do them up natural and if I learn that they should be painted it's an easy fix to pull them for a paint job, not so if done in the reverse.
Re: Leaf Spring rebuild kit? [Re: ScottSmith_Harms] #1318856
10/14/12 06:11 PM
10/14/12 06:11 PM
Was everything from Hamtramck painted or did it just pertain to certain body styles? Looking to get the correct finish on my 69 Charger leaf springs that is a Hamtramck car also.
Re: Leaf Spring rebuild kit? [Re: ] #1318857
10/14/12 06:14 PM
10/14/12 06:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I can't say, I've seen what appeared to be originals both ways
Re: Leaf Spring rebuild kit? [Re: ] #1318858
10/16/12 12:55 PM
10/16/12 12:55 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I have 2 Hamtramck built '69's and both appear to have been natural. Both built late '68. Of course yours may vary.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Leaf Spring rebuild kit? [Re: Dixie] #1318859
10/16/12 10:38 PM
10/16/12 10:38 PM
ok, the ones that were on my car originally appeared to have been natural steel originally and not painted. Just wanted to be sure as 40 years a lot of things can be changed.
Re: Leaf Spring rebuild kit? [Re: ] #1318860
10/19/12 08:32 PM
10/19/12 08:32 PM
New Mexico
New Mexico
Update. got mine all apart...had to cut off one center bolt...
Had all the pieces sandbalsted.. picked up today and suprise..my can of RPM was in the mailbox. Awesome stuff!! all treated and waiting on my rebuild kit and new bolts... they look good!!
