Trying to identify some 340 dampers. Did they all have casting numbers cast into them? I have a couple that I can't seem to find any on. I know they are for use on a forged crank. One of them is flat on both sides, the other is concave on the back side.
The other thing I am in question on is if you can use a 68-69 damper with a 70 timing cover. Can some one school me on mixing 340 timing covers and dampers used with a forged crank. Don't want to end up with a timing mark mismatch or any other problem.
Dan.
