Dumb Question #1318462
10/10/12 01:47 PM
10/10/12 01:47 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Alternator slip-on connectors (blue and green wires) --- does it matter how they are connected to the alternator? If so, where do I land each one relative to the alternator? Tahnks
Re: Dumb Question [Re: 70VERT] #1318463
10/10/12 01:53 PM
10/10/12 01:53 PM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
The green wire will be on the top post, the blue on the lower post..
Re: Dumb Question [Re: meep_meep] #1318464
10/10/12 02:09 PM
10/10/12 02:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Really makes NO difference. Unless you are a purist.
Re: Dumb Question [Re: MoparforLife] #1318465
10/10/12 04:24 PM
10/10/12 04:24 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
The two terminals are the opposite ends of the same 'wire'. It will work with the wires hooked up either way.
Re: Dumb Question [Re: hooziewhatsit] #1318466
10/10/12 04:33 PM
10/10/12 04:33 PM
unless the wires' insulation is old/hardened & has taken a "set" & will fit better with less bending on one way than the other then as said either way is fine
Re: Dumb Question [Re: RapidRobert] #1318467
10/11/12 01:11 AM
10/11/12 01:11 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The alternator field wires don't care which way they're connected.
