Neutral safty switch?? What to do for 4spd swap??? #131819
10/03/08 10:24 PM
10/03/08 10:24 PM
St.Clair Shores, Mich
bryansgarage Offline OP
67 Valiant ,was a 904 ,with a single wire neutral safety switch. We swapped in the 833 4spd and now we have a "no start" condition. I can kick the starter by touching off the relay, but we have nothing at the key. I even tried hooking up the neutral safety switch and holding it in , but still nothing.
We had this problem before with the 904 and it was the switch and tightening the wire solved it then.
My pedals dont have a switch either, like later models do.
Any ideas?
Re: Neutral safty switch?? What to do for 4spd swap??? [Re: bryansgarage] #131820
10/03/08 10:33 PM
10/03/08 10:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ground the wire from the g terminal (NSS TERMINAL)on the starter relay to one of the screws or bolts that you used to mount it.
Re: Neutral safty switch?? What to do for 4spd swap??? [Re: stumpy] #131821
10/03/08 10:43 PM
10/03/08 10:43 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
The relay will not function, if it is not allowed to ground on that lead.
Re: Neutral safty switch?? What to do for 4spd swap??? [Re: dave571] #131822
10/04/08 09:21 AM
10/04/08 09:21 AM
Thanks! I'll try that this morning and let you know the results.
Re: Neutral safty switch?? What to do for 4spd swap??? [Re: bryansgarage] #131823
10/04/08 11:08 PM
10/04/08 11:08 PM
Thanks again! That cured it. We made a new ,short jumper wire and it fired right up.
Re: Neutral safty switch?? What to do for 4spd swap??? [Re: bryansgarage] #131824
10/05/08 04:21 PM
10/05/08 04:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
