E-85 Holley users.....Have a few questionzzz #1317501
10/08/12 06:33 PM
10/08/12 06:33 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
From my understanding there are issues with fuel bowl, metering block and power valve gaskets standing up to the E-85 formula. Exactly what issues are you seeing if any and what gaskets are you using?
If you are having issues with gaskets, how long do they last before trouble sets in?
I have entered the arena of Holley gaskets and would like to test some out on E-85 and see how they fair against the competition
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317502
10/08/12 06:39 PM
10/08/12 06:39 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
I have not had issues with the gaskets, I have run E-85 for 3 years but only 2 count as I have not had the car out in a year.
What I see is a white powdery substance in the bowls and metering blocks.
I figured it was from not emptying the bowls when I put the car up for a while. I have found the fuel lines, mine are all braided rubber, are a little stiff.
But again no issues with gaskets....
Re: E-85 Holley users.....Have a few questionzzz [Re: mopartony] #1317503
10/08/12 07:19 PM
10/08/12 07:19 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well it does seem like the no stick one's stick. I never thought about it being the e-85. not sure what you can do about it.
Re: E-85 Holley users.....Have a few questionzzz [Re: VernMotor] #1317504
10/08/12 08:31 PM
10/08/12 08:31 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Yeah the metering block and fuel bowl gaskets stick usually tearing them and having to put new in. I am running your base plate gasket and it has seemed to hold up fairly well. Maybe try the same coating you are using on your other gaskets and see how well they would hold up. If you need someone to test I would more than happy to try them.
Re: E-85 Holley users.....Have a few questionzzz [Re: Hunted Duck] #1317505
10/09/12 10:41 AM
10/09/12 10:41 AM
Ohio
racerAL Offline
racerAL  Offline
Ohio
hi Greg, like what already has been said, its mainly the gasket sticking that's the biggest issue i have. if ya need someone to try them out, i have no problem trying them. i plan on racing 2 more times this year .
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317506
10/09/12 10:49 AM
10/09/12 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Greg I dont have any real problems with the non stick
(but they dont release like they should but I dont
think its the fuel).. might try using a viton coating
on them.... I wish the bowls and ALL of the alum parts
had a better hard coat... the water carried in the fuel
tends to corrode the alum
Re: E-85 Holley users.....Have a few questionzzz [Re: MR_P_BODY] #1317507
10/09/12 11:46 AM
10/09/12 11:46 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I would try some Pam cooking spray on them
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: E-85 Holley users.....Have a few questionzzz [Re: wildcargo] #1317508
10/09/12 12:12 PM
10/09/12 12:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've done that.. didnt change anything
Re: E-85 Holley users.....Have a few questionzzz [Re: MR_P_BODY] #1317509
10/09/12 12:58 PM
10/09/12 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Chap-stick user here BUT, not w/e-85 but it works great w/the ethonol crap aroud here..........
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317510
10/09/12 01:04 PM
10/09/12 01:04 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
We just do a little more maintenance with the E-85...Keep carb drained when not in use, inspect bowls & gaskets for corrosion and deterioration, change accel pump diaphragms & check the springs as they get corrosion on them. During engine warm-up we spray carb cleaner in air bleeds and on to boosters. No problems
Re: E-85 Holley users.....Have a few questionzzz [Re: MoparPitBull] #1317511
10/09/12 09:20 PM
10/09/12 09:20 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Well what I've been hearing is the E-85 has been especially troublesome with the gaskets sticking to the components. Also some issues with gasket swell and delamination.
This has been from many popular brands of gaskets.
I'd like to find someone who runs E-85 to test a set of what I have. Testing so far they work real well with pump gas and race fuel. So good in fact when the bowl is removed the metering block usually falls off to
Jeff do you run Ethanol? Are you doing any more racing this year?
These are made from the same material as the base gaskets
I know what you all mean with them sticking as I've had to beat the bowls & blocks of many times myself
I appreciate all the responses
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317512
10/09/12 09:24 PM
10/09/12 09:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I have 3 more races this year ..send them to me !! LOL
Re: E-85 Holley users.....Have a few questionzzz [Re: VernMotor] #1317513
10/09/12 09:39 PM
10/09/12 09:39 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
You run the E-85 Jamie?
If so PM me your details or give me a
1-866-925-7855
What brand gaskets do you have now? Are you happy with them?
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317514
10/09/12 09:51 PM
10/09/12 09:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yes I have run e-85 for 2 years now.I have been using holley and quick fuels both.
Re: E-85 Holley users.....Have a few questionzzz [Re: VernMotor] #1317515
10/09/12 10:22 PM
10/09/12 10:22 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Got your PM
I assume you run a 4150 style 2 circuit carb? Want to get you the right set as I offer them for the 4500 3 circuit as well
Pic #1 is the 2 circuit
Pic #2 is the bowl gasket
This is the 3 circuit
Re: E-85 Holley users.....Have a few questionzzz [Re: roadhazard] #1317516
10/09/12 10:30 PM
10/09/12 10:30 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well hells bells !! lol I got a 950HP holley on it right now .I thought it was a 4150. I need to get info on this ?? I never heard or had anyone say this to me before or read it. Ok I got a 4150 a 4500 is a Holley 4500 HP Dominator. Brain fart LOL
Re: E-85 Holley users.....Have a few questionzzz [Re: VernMotor] #1317517
10/09/12 10:37 PM
10/09/12 10:37 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
DOH!!
Re: E-85 Holley users.....Have a few questionzzz [Re: moparguy7074] #1317518
10/09/12 10:39 PM
10/09/12 10:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
some days are like this LMAO..just got to stop and engage brain
Re: E-85 Holley users.....Have a few questionzzz [Re: VernMotor] #1317519
10/10/12 08:48 AM
10/10/12 08:48 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Maybe it was just past your bedtime
I'll send you my 2 circuit kit today for testing.
2 Bowl Gaskets
2 Metering Block Gaskets
2 Power Valve Gaskets
8 Nylon Fuel Bowl Screw Washers (these will not be available until later in the month), hope you have some already.
Put 'em on, let her rip and tell us what you think
