Role Cage Install price??? #1317424
10/08/12 04:38 PM
10/08/12 04:38 PM
Everett, Wa.
Jason440 Offline OP
Jason440  Offline OP
Everett, Wa.
I was asked to install a 12 point mild steed cage in a friend of a friends car and I have no idea what to charge since I have only done this stuff for myself and my father.
The scope of the project:
12 point Mild Steel cage. I’m Going to recommend an S&W kit.
Dash bars thru the dash – May make these bars myself.
Swing out door bars.
Sub frame connectors – May need to build these myself.
I plan on tig weld the cage.
Thanks for your help.
Re: Role Cage Install price??? [Re: Jason440] #1317425
10/08/12 04:45 PM
10/08/12 04:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
If you're going to TIG it why not go Moly?
$100 per point is generally a rule of thumb, probably on the low side since its TIG welded but location plays a factor in price as well.
EDIT: I see you're local, call Pircey Race cars and ask what he charges. Good chassis work isn't cheap.
http://www.ronpirceyenterprises.com/wordpress/
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Role Cage Install price??? [Re: Triple Threat] #1317426
10/08/12 04:54 PM
10/08/12 04:54 PM
Everett, Wa.
Jason440 Offline OP
Jason440  Offline OP
Everett, Wa.
She didn’t want the added expense of moly but I will sagest it again…
I’m tig welding it because that is how I prefer to do it. The car will see some local cruse locations too.
Re: Role Cage Install price??? [Re: Jason440] #1317427
10/08/12 04:54 PM
10/08/12 04:54 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I personally would like to see your work, because I am in the market for the same kind of roll bar install. If you have the skills to do a tig welded install, you should be charging a professional price, less the "family discount" of course. You should be able to get a feel for what the market will bear by looking at some of the Craigslist ads. BTW, why not go with a Morrison kit? They are a lot closer in Fife>
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Role Cage Install price??? [Re: Polarapete] #1317428
10/08/12 06:43 PM
10/08/12 06:43 PM
Everett, Wa.
Jason440 Offline OP
Jason440  Offline OP
Everett, Wa.
Here is a pic of my "66 Satellite.
http://sphotos-a.xx.fbcdn.net/hphotos-prn1/68327_4014406153503_264854006_n.jpg
And a shot with the nose mocked up.
http://sphotos-b.xx.fbcdn.net/hphotos-snc6/183393_3948471345174_1741792269_n.jpg
I havn't posted any build picks for quite some time...
