help! 1970 B-Body Rear Lighting wiring question.... #131741
10/03/08 08:20 PM
10/03/08 08:20 PM
Anonymous OP
Anonymous OP
1. When we switch the ignition on - all of the rear running lights come on.
2. The brake lights don't come on when the brake switch is activated.
3. The brake light switch is OK when we do a continuity check.
4. There are two hot leads going to the brake switch.
5. When we jump the brake switch the rear brake lights don't come on.
6. When we put power to the connector that feeds the brake lights they do come on.
7. All of the bulbs are OK.
Any ideas on solving this mystery wiring problem??
Re: help! 1970 B-Body Rear Lighting wiring question.... #131742
10/03/08 11:49 PM
10/03/08 11:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sounds like someone swaped wires around and have the brakelights plugged into the wrong place, same for the extra hot lead at the brake switch.
Is the wiring harness a stock one? If it is, you could use a factory service manual and varify the correct color wires are connected to the correct switches. If the wiring harness is a mess of aftermarket wiring, you will have to trace the wires to and from the correct connection points.
Re: help! 1970 B-Body Rear Lighting wiring question.... #131743
10/04/08 07:20 AM
10/04/08 07:20 AM
Australia
charger RTSE Offline
Australia
Did it work before or did it just happen.Have you played around with the turn signal switch or wiring in the steering column by any chance.
Re: help! 1970 B-Body Rear Lighting wiring question.... [Re: charger RTSE] #131744
10/04/08 04:26 PM
10/04/08 04:26 PM
Anonymous OP
Anonymous OP
The dash has been apart before I got the car. So I'm trying to track down the gremlin.
Thanks.
Re: help! 1970 B-Body Rear Lighting wiring question.... #131745
10/04/08 04:28 PM
10/04/08 04:28 PM
Anonymous OP
Anonymous OP
where are the emergency flasher unit and the turn signal flasher unit?
Re: help! 1970 B-Body Rear Lighting wiring question.... #131746
10/04/08 04:35 PM
10/04/08 04:35 PM
Renton, Washington
Bobster Offline
Bobster  Offline
Renton, Washington
I had a weird problem with my Challenger. Traced the whole thing back to the signal switch in the steering column.
I replaced that thing and haven't had any trouble since.
Also, the greatest tool you can have when working with electrical stuff is a wiring diagram. www.classiccarwiring.com is one of the best sources I can recommend.
Re: help! 1970 B-Body Rear Lighting wiring question.... [Re: Bobster] #131747
10/04/08 05:13 PM
10/04/08 05:13 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
pavell
sent you an email
let me know if I can help
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: help! 1970 B-Body Rear Lighting wiring question.... [Re: 7DRRunner] #131748
10/04/08 11:12 PM
10/04/08 11:12 PM
Anonymous OP
Anonymous OP
Thanks I got the email! I appreciate it!
Re: help! 1970 B-Body Rear Lighting wiring question.... #131749
10/05/08 09:36 AM
10/05/08 09:36 AM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
glad to help
good luck with the fix
Re: help! 1970 B-Body Rear Lighting wiring question.... [Re: 7DRRunner] #131750
10/11/08 03:01 PM
10/11/08 03:01 PM
Anonymous OP
Anonymous OP
Thanks guys,
I figured it out!
Re: help! 1970 B-Body Rear Lighting wiring question.... #131751
10/11/08 03:41 PM
10/11/08 03:41 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
glad to hear it
