Hemi bearing question.... #131737
10/03/08 08:14 PM
10/03/08 08:14 PM
A Red State
SNK-EYZ Online tonguue OP
SNK-EYZ  Online Tonguue OP
A Red State
I'm trying to order bearings for the 572 Hemi I'm building.
The block is a new Mopar Performance/World Products cast iron block part # P5153861.
The crank is a 4.5 stroke Keith Black billet crank turned .010 under.
I'm trying to figure out what are the best bearing to use for my application which will mostly be street use (with the occaisional runs at the track).
From talking to different people the brand choice recommended is Clevite 77 tri-metal.
But from there Clevite makes different ones.
The crank has radiused journals and one place recommends the narrower but harder race bearings (MS2233HG10).
But since it's really a street engine would the MS896P be a better choice?
Suggestions...Opinions??
Thanks, Rich
Re: Hemi main bearing question.... [Re: SNK-EYZ] #131738
10/03/08 08:20 PM
10/03/08 08:20 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
p series is pass car stock type h= heavy duty and narrow will work, v- series is best narrow and 1/2 or 3/4 groove get mine from 440 source
MOPAR OR NO CAR
Re: Hemi main bearing question.... [Re: hemigod426] #131739
10/03/08 08:35 PM
10/03/08 08:35 PM
A Red State
A Red State
Forgot to ask also, what outside diameter thrust main does the MP/World block need?
Does it use the 73 and earlier (3.555-3.675) or the 74 and later? Which so far no one has been able to tell me the diameter of.
When I measured the block there it was 4.00 in.
Re: Hemi bearing question.... [Re: SNK-EYZ] #131740
10/03/08 08:52 PM
10/03/08 08:52 PM
hemigod426 Offline
hemigod426  Offline
world block has std cam and main bearing like 66-73 440. any h or v bearing will work with your crank
MOPAR OR NO CAR
