Chasing gremlins in cooling system #1316798
10/07/12 07:06 PM
10/07/12 07:06 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
On the hunt for my cooling issues...I warmed up the engine today and hit 200ºF...I consequently shut the engine off and the viscous fan stopped spinning. I reached into the engine bay and the viscous fan still turns by hand. I know that if the engine was shut off and the fan was still spinning it was going to need replacing.
This was my first step since it didnt require removing anything.
Next up is the timing.
Is my viscous fan still good?
Does the the amount of blades make a difference? I have a 7-blade fan on the system now.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316799
10/07/12 07:15 PM
10/07/12 07:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
200 degrees isn't hot, why do you think you have an issue?
Don't be the exception.
Re: Chasing gremlins in cooling system [Re: Supercuda] #1316800
10/07/12 07:20 PM
10/07/12 07:20 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
200* isn't dangerously hot. But if you have a 180* t-stat, then it's unusual and may need attention. If the cooling system is working properly, it should rarely go above 180* or whatever your t-stat spec is. I run a fixed fan, but from what I understand, when you spin the fan with your hand, if the fan spins for more than 1 to 1-1/2 revolutions without resistance, or if it does not move at all, you need to replace it. Some say 3 revolutions, but that seems a lot to me. Also if there's a lot of slop in it.
Re: Chasing gremlins in cooling system [Re: bobs66440] #1316801
10/07/12 07:36 PM
10/07/12 07:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is exactly opposite of how a thermostat works. The thermostat controls the MINIMUM temperature, not the maximum.
Re: Chasing gremlins in cooling system [Re: Supercuda] #1316802
10/07/12 07:44 PM
10/07/12 07:44 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
well last weekend my Autometer gauge rolled over past 240ºF and was heading for the 0 again...As it idles in park for 15 minutes
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316803
10/07/12 07:47 PM
10/07/12 07:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ah, that is bad assuming the gauge isn't bad. Generally, cooling issue at idle/low speed are airflow relate. Can you borrow another fan setup to verify the clutch is out?
Re: Chasing gremlins in cooling system [Re: Supercuda] #1316804
10/07/12 08:02 PM
10/07/12 08:02 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Well..I believe the temp gauge is working...it got so hot, I got Vapor Lock as a result and the engine shut down. I dont have another fan but I do have a spare viscous clutch on my shelf.
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316805
10/07/12 09:02 PM
10/07/12 09:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Swap it out and see if it works.
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316806
10/07/12 09:12 PM
10/07/12 09:12 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
if it cools good at highway or even long steady city speeds,the cooling system is working(Rad is good) but at idle or crawling along in hot weather You are not drawing enough air through the rad...hence the fan issue...so if the fan is not spinning enough to draw air...the clutch is weak and should be replaced.
Re: Chasing gremlins in cooling system [Re: terzmo] #1316807
10/07/12 09:53 PM
10/07/12 09:53 PM
Central TX
roe Offline
roe  Offline
Central TX
1 exception may be a clogged up radiator (water flow restriction). Mine would get too warm in traffic/at idle, but would cool down at speed. Took a look inside and the passages I could see were pretty clogged, almost closed. Had it flow tested and it was verified by the rad shop as being severely clogged up.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Chasing gremlins in cooling system [Re: Supercuda] #1316808
10/07/12 10:06 PM
10/07/12 10:06 PM
bobs66440 Offline
bobs66440  Offline
Ahh, right.
Mine would run fine at highway speeds and heat up through town or at idle. I installed a new 26" aluminum rad and it was much better. I also installed a smaller water pump pulley to speed up the fan and the water flow and that also helped. Now it will idle almost indefinitely and stay at 180.
To the OP, I would just ditch the fan clutch and run a fixed fan. Fixed fans put a little more stress on the engine and rob a little HP, but nothing you will notice and they won't fail and cook your engine.
Re: Chasing gremlins in cooling system [Re: bobs66440] #1316809
10/07/12 10:21 PM
10/07/12 10:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The thermostat doesn't control the high end of the temp. If you run a 165* stat you shouldn't expect the engine to run that temp. All the stat does is slows water flow until the engine reaches the stats open temp. If the engine runs above that,which most normally do, the stat will never close.
Re: Chasing gremlins in cooling system [Re: stumpy] #1316810
10/07/12 10:37 PM
10/07/12 10:37 PM
bobs66440 Offline
bobs66440  Offline
Right, I stand corrected and agree. The t-stat controls the lower end and the cooling system design controls the upper end. The t-stat just doesn't let it get below the spec temp.
Re: Chasing gremlins in cooling system [Re: bobs66440] #1316811
10/07/12 11:49 PM
10/07/12 11:49 PM
Eastern shore, New England
roadrunner69s Offline
My '68 GTX 4 speed had similar problems with highway vs idle speed. On hot summer days it would run around 200-210 on the highway and at idle would easily get to 225 and keep going. Even after going through every cooling system component including a 3 row recore of the 26" radiator, nothing changed. I even got to the point of swapping back to an orig cam, rejetting the carb, advancing the timing, running a 98-100 octane mix, using infra-red heat guns, tighter gripping fan belts or better fitting pulleys, removing any vacuum leaks, and running 90% water with Redline water wetter. All of that helped....a little. After 3 yrs of trying I finally sold the car w/o ever solving the problem. No doubt an alum radiator with high capacity water pump would have helped some. It was annoying that between my Mopar mechanic and myself we could never find the smoking gun. The setup was basically stock with the proper 7 bladed fan/shroud and stock viscous fan. I do have to wonder if the new Year One repro fan shroud was part of the problem as they are not as deep as the originals, hence the fan blade protrudes out a tad. Could have made a difference. The idle engine vacuum ran around 8-12" as I recall which I felt was a symptom. Normal would have been around 14" or greater. My hunch was that a less than optimum fuel/air ratio was the source of the overheating.
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316812
10/08/12 07:51 AM
10/08/12 07:51 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
Both of my cars will idle at 200* all day long on a 100* day with the A/C on and a 195* thermostat with stock cooling systems. One thing that may have been overlooked is to be sure the fan clutch unit is a HD one for the 7 blade fan setup. I used to run the standard unit and had the same symtoms as described above and discovered the standard one will not spin the heavier 7 blade fan fast enough at idle or low speed. Not only is the 7 blade fan heaver but it has more resistance to turn as it moves more air.
Re: Chasing gremlins in cooling system [Re: roadrunner69s] #1316813
10/08/12 08:53 AM
10/08/12 08:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly right if everything else was right.
With todays alcohol fuel our fuel systems need to be richer with plenty of timing to run cool. 10% alky required jetting up even though guys will swear there right jetting wise because they have o2 sensor in the exhaust, there still lean and don't even know it and blame everything except the tune up.
Re: Chasing gremlins in cooling system [Re: Mopar73340] #1316814
10/08/12 02:34 PM
10/08/12 02:34 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I just checked and its a Hayden 2747 Heavy Duty Thermal. As far as driving on the highway...I can open her up going 75 and the temperature stays about 190º (given its a 180º thermostat)
I need to play with the air bleed screws a little bit and bring my vacuum up. In Drive its pulling 9". I used to have 12" but I swapped out to Dual Quads.
As far as checking the radiator if its plugged up, I would need to find a Radiator shop that actually has old school tools. Thats a needle in a haystack where I live. I replaced my coolant about 9 months ago because I swapped out to aluminum cylinder heads. I wanted to freshen up the cooling system. IIRC, the coolant was still Green, no rust color and I refilled it to 50/50 again. I have to pull one of my plugs and see how the color looks too...hopefully they aren't pitch black
Re: Chasing gremlins in cooling system [Re: Supercuda] #1316815
10/09/12 02:46 PM
10/09/12 02:46 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The thermostat controls the maximum.
Anything under the temperature, it's regulating. Anything over and it's wide open with NOTHING LEFT.
We need to know when it's reaching 200. Idling, city cruising, highway. Will it recover? Does it ever maintain thermostat temperature?
Re: Chasing gremlins in cooling system [Re: Pyper70] #1316816
10/15/12 03:35 PM
10/15/12 03:35 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I swapped out the old clutch for the fan with the new unit. i don't think anything was wrong with it but it doesn't matter. 15 minute job. I did bump the timing to about 18 degrees. (my timing tape somehow came off even though it was super glued on and clearcoated)...I need to perhaps try a little more...maybe 20 and play with the idle mixture screws a little. I got my vacuum up to 12" but I am also revving at 1100...So I need to bring that down with the next test and tune.
