TIG welder blues....... #1316615
10/07/12 02:22 PM
10/07/12 02:22 PM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
I needed to weld some moly tubing Saturday and all I got was.. pop pop pop and it blew a hole in the metal! It's a Lincoln Square Wave.
I only use it a few times a year now and the last time was probably 5 months ago. It worked ok then but now it pops and I can't get it to weld no matter what..
Any ideas on what to look for? I cleaned the metal and adjusted amps.
I'm wondering if I've forgotten how to tig weld
Re: TIG welder blues....... [Re: 52savoy] #1316616
10/07/12 06:25 PM
10/07/12 06:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You need to have a pointed tungsten, DC straight, you need to tell us what your welder is set up, gas, metal thickness, tungsten diameter, flow rate, etc. Tim
Re: TIG welder blues....... [Re: astjp2] #1316617
10/07/12 10:50 PM
10/07/12 10:50 PM
State of Fascism
52savoy Offline OP
52savoy  Offline OP
State of Fascism
Yes it's pointed.. I believe it's 3/32 2%, DC-, flow meter set at 15,
and the metal is about .080 wall
I tried settings from 40 to 70 amps and it still popped(loud).
and going to try it again Monday with some scrap metal but check connections/corrosion first.
http://www.millerwelds.com/resources/art...ome-Moly-Tubing
Re: TIG welder blues....... [Re: 52savoy] #1316618
10/08/12 12:33 AM
10/08/12 12:33 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
There are some pretty good tips on this site.
http://www.weldingtipsandtricks.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: TIG welder blues....... [Re: 52savoy] #1316619
10/08/12 12:46 AM
10/08/12 12:46 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I think you have oils on the metal, wash it down with acetone/denatured alcohol. Are you using high freq start or scratch start? Try DC straight also. Tim
Re: TIG welder blues....... [Re: astjp2] #1316620
10/08/12 02:29 AM
10/08/12 02:29 AM
California
Mad Dart Offline
Mad Dart  Offline
California
Clean the metal as stated above. Make sure you got a good ground. Floor the pedal and back off it when you get a good arch going. Carry on as normal.
