Re: Factory mis stamped engine/trans engine code?
[Re: mopars4life]
#1316272
10/06/12 03:48 PM
10/06/12 03:48 PM
Posts: 4,795 Castlegar, BC, Canada
That AMC Guy
I had a '68 New Yorker once that I traded to a friend. He pulled the engine for a '68 Charger he was working on. Now, I'm not familiar with 1968 engine stampings, but he told me the engine was stamped to be a TNT/Magnum engine, but that letter was crossed out and the correct letter for the 350-horse 440 followed.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: mopars4life]
#1316273
10/06/12 06:54 PM
10/06/12 06:54 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Is your Charger a pre-Jan. '69 car with the full VIN# stamped on it? & you're saying it has XP29F9B 123456 stamped on a 383 block & your VIN# is XP29H9B 123456? I've seen a 440 block with the same deal - GOT a pic? I think I have a pic of the 440, I'll see if I can find it. (bet they're same day, on the line)
[Re: 6bblgt]
#1316274
10/06/12 07:58 PM
10/06/12 07:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The 413 in my 64 300 was stamped T for 63, then over stamped with a V for 64. Everything about the engine was 63, 4 bolt valve covers, casting numbers, etc.
[Re: RAH]
#1316276
10/07/12 11:24 AM
10/07/12 11:24 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
My 1968 dodge Hemi charger has original engine and trans. . the person who stamped the vin on the engine and trans missed one digit on both the engine ant trans vin XS29J8b3062xx engine and trans are stamped 8b362xx the 0 was missed on the engine and trans.
I have a 68 hemi 4-speed that is missing the same digit, 5th from the end, same plant.
[Re: 340KID]
#1316280
10/11/12 05:39 PM
10/11/12 05:39 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
on my 1972 Cuda 340 - the vin plate is coded BS23G4xxxxx, while it should be BS23H4xxxxx vin says it's a 318 while i have the original 340 in it, build sheet also denotes BS23G but all the specs point to the 340 and the vin numbers agree on the block
What's the fender tag say?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 340KID]
#1316281
10/11/12 06:43 PM
10/11/12 06:43 PM
6bblgt
Las Vegas, NV
both those examples would be 1974 GOT PICS?
[Re: DPelletier]
#1316283
10/11/12 07:37 PM
10/11/12 07:37 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
yep, something fishy there...
Well, it is a Cuda.
[Re: 6bblgt]
#1316284
10/12/12 12:04 AM
10/12/12 12:04 AM
Posts: 549 CT
340KID
CT
Why 1974 ?
[Re: 340KID]
#1316285
10/12/12 12:18 AM
10/12/12 12:18 AM
Posts: 29,651 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Why 1974 ?
The 4 in that position is the model year, 1974.
But - The VIN you listed - "BS23H4xxxxx" is two digits short. So, what is the whole thing?
[Re: 340KID]
#1316287
10/12/12 12:31 AM
10/12/12 12:31 AM
Posts: 549 CT
340KID
CT
Just checked BS23G2B 4xxxxx I forgot the 2B
I need to pull build sheet , but I recall engine code was E55
