Removing headrests #1316148
10/06/12 11:44 AM
10/06/12 11:44 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Has anyone recently removed headrests from '69 B-body bench?
The drivers side came out with a little bump, after it was fully
extended. The pass. not so easy. Is there a trick, I don't want
to break anything?
Re: Removing headrests [Re: demonH1B] #1316149
10/06/12 11:29 PM
10/06/12 11:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The headrest tend to stick and you won't break anything by pulling on them hard. The only problem I had once was smashing my hand on the roof and putting a dent in it under the headliner... Sometimes it helps to tilt it forward or rearward when pulling.
JB Rhinehart, Realist
A-Body's RULE!
Re: Removing headrests [Re: Rhinodart] #1316150
10/11/12 09:37 PM
10/11/12 09:37 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I had one that was stuck in my Duster, and when I wrestled it loose, it continued upwards and ripped the head liner when it struck with force. Be careful, probably better to tip the seat forward and work.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
