Re: Alternator Rebuild of Your Original?
[Re: 68jim]
#131622
10/05/08 10:26 AM
10/05/08 10:26 AM
Posts: 2,484 Minneapolis, MN
hemi70se
Minneapolis, MN
I'm quite happy with their work also. This is the original Alt for my Road Runner.
Jim 68 Hemi Road Runner
Can you tell how they refinished your case? Is it silver paint or something else?
[Re: hemi70se]
#131623
10/05/08 10:31 AM
10/05/08 10:31 AM
Posts: 21,487 It's a dry heat
gtx6970
It's a dry heat
Ancient chinese secret,,,,,,
I've seen Jim's work in person and it's not paint
[Re: hemi70se]
#131624
10/05/08 10:29 PM
10/05/08 10:29 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Glass bead blasted?
[Re: In_The_Pink]
#131625
10/06/08 10:09 AM
10/06/08 10:09 AM
hemi70se
Minneapolis, MN
Glass bead blasted?
Could be, but that would not be a good choice because the beads would be too aggressive and alter the cast smooth surface. You could use more of a powder type abrasive with a lower pressure, but with either method you are still leaving it bare aluminum and it will corrode with time. I believe the factory method of corrosion protection was a dichromate dip, but I haven't found any company yet that would be willing to do it.
