A999 hard parts #1316075
10/06/12 12:43 AM
10/06/12 12:43 AM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
After searching high low and sideways I finally found (to me anyways) the holy grail of obscure transmissions. A lockup A999 out of soon to be mine 85 B250/318 passenger van I bought for parts.
One owner van that the guy maintained fairly well over its lifespan, its got approx 230K on the original transmission that was given regular fluid/filter changes.
I am looking to do good stockish rebuild on the transmission and then drop it into my 79 B200/318. I looked in the usual places and besides going through the dealership for the hard parts like planetarys and snap rings. I couldnt find a whole lot for it ? The double wrap rear band part number I have from the 85 parts catalog comes back as no good with mopar ? Is it the same band as the newer 42/44 RH/RE transmissions ? Does anyone in the aftermarket offer new or remaned planetary units for these or is Mopar the only source ? I'm sure theres more i'm forgetting but those two things are what came to mind right now.
Thanks.
Re: A999 hard parts [Re: 135sohc] #1316076
10/06/12 06:52 AM
10/06/12 06:52 AM
scratchnfotraction Offline
maybe check a local trans shop in your area.
Re: A999 hard parts [Re: scratchnfotraction] #1316077
10/06/12 08:37 AM
10/06/12 08:37 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Isn't that just a 904 with overdrive? I believe they're all based on the 727.
Re: A999 hard parts [Re: redraptor] #1316078
10/06/12 09:16 AM
10/06/12 09:16 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's an "HD" version of the 904, came behind 360's. I think it got a better band and an extra clutch. If John sees this he can fill us in better.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: A999 hard parts [Re: 135sohc] #1316079
10/06/12 10:07 AM
10/06/12 10:07 AM
Lehigh Acres, Florida
rickstershemi Offline
Thanks.
http://www.google.com/imgres?start=0&...&ved=1t:429,r:5,s:0,i:96
Re: A999 hard parts [Re: rickstershemi] #1316080
10/06/12 11:44 AM
10/06/12 11:44 AM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
The last time I went there and they proceeded to lose a very hard to find part of mine. They can go to hell.
Robert
pretty much. I knew going in that it was a 318 so to find it still had the 999 transmission was an unexpected bonus.
Re: A999 hard parts [Re: 135sohc] #1316081
10/06/12 02:10 PM
10/06/12 02:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Try here.
999 Parts
Re: A999 hard parts [Re: John_Kunkel] #1316082
10/06/12 10:59 PM
10/06/12 10:59 PM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
Does anyone offer new/rebuilt planetaries or are they going to be a dealer only item ? I see CRT lists several for the 727 but nothing for the 904 family.
Re: A999 hard parts [Re: 135sohc] #1316083
10/07/12 04:50 AM
10/07/12 04:50 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.aandatrans.com/Default.aspx
they had hard parts for 999.
Tony
70 AARCuda Vitamin C
Re: A999 hard parts [Re: 135sohc] #1316084
10/07/12 02:12 PM
10/07/12 02:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Planetaries in the 3-speeds don't usually go bad because they're only used in the lower two gears...unlike the OD's which run constantly. If and when one fails just replace it with a servicable used unit.
Re: A999 hard parts [Re: John_Kunkel] #1316085
05/28/13 11:23 PM
05/28/13 11:23 PM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
Got all the non dealer only parts ordered besides a cast pan and band strut. Dealer parts ordering tomorrow and then the fun starts. I have done a few transmissions before, this is my first automatic.
Re: A999 hard parts [Re: 135sohc] #1316086
05/29/13 12:01 PM
05/29/13 12:01 PM
dogdays Offline
dogdays  Offline
So, a 318 usually had a 998... What makes you sure that this is a 999?
Let us know how many clutch disks, etc.
R.
Re: A999 hard parts [Re: dogdays] #1316087
05/29/13 01:47 PM
05/29/13 01:47 PM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
R.
5 in the front, 4 in the rear.
I know it is the original unit to the Van and the options sticker calls out A999 specifically.
I'm assuming they went with the 999 vs 998 atleast in B-vans because of the extra weight its always hauling around. The parts catalog makes no mention of the 998 at all.
Re: A999 hard parts [Re: dogdays] #1316088
05/29/13 02:11 PM
05/29/13 02:11 PM
Kansas
cascius Offline
cascius  Offline
Kansas
I believe the 318 mostly used a 904. The 998 and 999 were more common behind the 360. The 904 has 3 forward clutches while the 998 has 4 and the 999 has 5. The 998 and 999 also have a lower 1st and 2nd gear ratio than the 904 does.
Re: A999 hard parts [Re: cascius] #1316089
05/29/13 02:27 PM
05/29/13 02:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The A998 (also referred to as the 904-1) was introduced in '74 specifically for use behind the 318. The low gearset didn't arrive until '80.
Re: A999 hard parts [Re: John_Kunkel] #1316090
05/30/13 01:04 PM
05/30/13 01:04 PM
dogdays Offline
dogdays  Offline
Thanks, John.
R.
