Mopar mini starter suddenly doesnt work
#1315970
10/05/12 09:14 PM
10/05/12 09:14 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
I was trying to get my car out of the trailer last weekend after sitting in there since the Norwalk Mopar event and the starter just clicked like the battery was dead. After a quick charge it turned over real slow and erratically like the motor had a spun bearing. I never had an issue with this starter or any indication of it going bad and it was purchased brand new, Could it have gone bad all of a sudden like that?? Or could there be something else that might be causing the symptoms? Battery is good. Thanks.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: Mopar mini starter suddenly doesnt work
[Re: G-Money1320]
#1315971
10/05/12 10:15 PM
10/05/12 10:15 PM
Posts: 1,532 off the grid
340B5
off the grid
Is there a small plastic cover on top of the starter? If so, pop it off and check the nuts for being loose.
Yeah, it's got a smallblock.
[Re: 340B5]
#1315972
10/05/12 10:28 PM
10/05/12 10:28 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
No cover, it is the style with the slide plug for the small wire.
[Re: dennismopar73]
#1315976
10/06/12 10:28 PM
10/06/12 10:28 PM
Posts: 9,836 MI, usa
dvw
MI, usa
you need to take the starter off the motor, take the selnoid aprt, fix the contacts!! a little aggravating, but will save you life time of issues
Greg, my bet this is the fix. I'd be happy to take a look at it for you. Doug
[Re: dvw]
#1315977
10/06/12 11:15 PM
10/06/12 11:15 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Ok Doug, im hoping to get the car pushed out of the trailer tommorrow and start pulling the starter out. The battery connections are clean as I clean them up before hooking them up. The starter never even gave me an indication of anything wrong as it started the car just fine, even when I pulled it in to leave Norwalk. I didnt know if anyone had run into this with the mini's or not. Thanks for the input.
[Re: 340B5]
#1315979
10/07/12 09:20 AM
10/07/12 09:20 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Before going to all kinds of work get a Volt meter.Hook it to the batt and have someone crank it.A bad battery will charge but not have enough to start the car.Ive seen new batterys that are bad.Easy to check.Just because you charged it dosent mean its good.Rocky
Chrysler Firepower
