intake torque spec same as ... #1315922
10/05/12 05:58 PM
10/05/12 05:58 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Is the torque spec for bb aluminum intake and heads the same as factory? (40ftlbs) Thanks
Re: intake torque spec same as ... [Re: 440forPOWER] #1315923
10/05/12 06:52 PM
10/05/12 06:52 PM
I use between 35 and 40 ft. lbs I do retorque them several times before running and agian several times after running them long enough time to get the motor hot
Re: intake torque spec same as ... [Re: Cab_Burge] #1315924
10/05/12 07:37 PM
10/05/12 07:37 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Re: intake torque spec same as ... [Re: 70VcodeCoronetRT] #1315925
10/05/12 11:51 PM
10/05/12 11:51 PM
Make sure and use a good quality flat washer under all the intake bolts, I do double up them sometimes(3/8 fneder washer and a 3/8 AN washer between the bolt and fender washer ) if the manifold bolts have been elongated or hogged out bigger
Re: intake torque spec same as ... [Re: Cab_Burge] #1315926
10/06/12 12:21 AM
10/06/12 12:21 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Some intakes are just plain tough to tq the inside bolts. I'm curious how some of you have done this, Maybe a crow's foot? I have owned intakes that you can't get a socket on, yet alone an extention and tq wrench
Re: intake torque spec same as ... [Re: Mopar-Al] #1315927
10/06/12 02:27 AM
10/06/12 02:27 AM
I use a 3/8 drive crowsfoot(actually not a true crowsfoot, they are box ends. See the picture) I need two more,3/8 and a 7 1/6. I have a 1/2 inch, 9/16 for B and RB intake bolts and a 5/8 for the intake valley head studs on the 426 Hemiroids. If you use these you need to do the math when adding extension onto the end of the torque wrench
Re: intake torque spec same as ... [Re: Cab_Burge] #1315928
10/07/12 09:24 AM
10/07/12 09:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive never torqued a BB intake.I use a 3/8s ratchet or a box wrench.Just get them to where they feel tight and it good.Ive been doing them since the 60s though.My aluminum I run a bit less than the factory though.Rocky
Chrysler Firepower
