Small block water pump interchangeability
#1315895
10/05/12 04:47 PM
10/05/12 04:47 PM
Posts: 2,515 PA
moparacer
PA
I have a 66 Barracuda that I am working on for someone that overheats. The coolant does not seem to circulate very fast after the thermostat is open and I noticed it has a old style cast iron water pump (67 and older I think) on a newer 80s 318 that originally took the newer style aluminum water pump.
Will these older style pumps work ok on the newer style timing chain covers?
Thanks!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Small block water pump interchangeability
[Re: scratchnfotraction]
#1315897
10/05/12 06:47 PM
10/05/12 06:47 PM
Posts: 2,515 PA
moparacer
PA
I pulled the rad and am going to flush it out or rod it out if needed.(I own a radiator shop) The coolant looks pretty bad so I am flushing the entire system and it had a 195 stat in it so I am going to replace it with a 180 and go from there. Just never seen a old style pump on a new style timing cover before. I know if the impeller isnt designed right it can cause a circulation problem.
[Re: RapidRobert]
#1315899
10/06/12 12:59 AM
10/06/12 12:59 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
What good is it going to do to change from the 195 to a 180 stat. The number ratings are for when the stat is wide open. If it doesnt flow well with the 195 its not going to flow any better with the 180. Rod out the rad..
I am truckless..
[Re: GO_Fish]
#1315902
10/06/12 07:01 AM
10/06/12 07:01 AM
Posts: 15,487 Florida
scratchnfotraction
Non A/c car I'm guessing??? Make sure it has the correct 8 (?) vane pump and not the a/c 6 vane pump. They had different diameter pulleys to spin the pump faster for a/c cars. Mixing and matching pulleys and pumps can cause cavitation and overheating.
I matched up the HD 5/8" shaft WP with 8 vanes with my larger non a/c pully on my SB.
runs right at the 180* t-stat rating.
for me the fix was a new replacement rad that was a max cooling all brass/copper 3 row rad. replacing a 35 yr old 2 row stock rad.
