Re: 318 to 390? [Re: Moparmal] #1315259
10/09/12 11:02 AM
10/09/12 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Lets see here... your gonna buy a stroke kit... that
part is a wash... why not buy a 360 block and get the
added cubes... that would cost about 200 buck more..
cubes are great for the street........ JMO
Re: 318 to 390? [Re: MR_P_BODY] #1315260
10/09/12 11:52 AM
10/09/12 11:52 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Pick up a later roller cam 360 block, everything else costs the same. Plus the larger bore of a 360 will help unshroud the intake valves.
Re: 318 to 390? [Re: justinp61] #1315261
10/09/12 12:01 PM
10/09/12 12:01 PM
Renton Washington
Triple Threat Offline
Renton Washington
And I owned a pretty stout 318-390" stroker. The same package with a 360-408" engine probably would have been worth another 20-30lb ft of torque at no added cost. 360 blocks aren't that hard to come by.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 318 to 390? [Re: Triple Threat] #1315262
10/09/12 12:21 PM
10/09/12 12:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
30lbs from 16 cubes not to mention bigger bearings robbing power due to the SB good valve position they do not see much more flow (a little but not significant) from a 3.91 bore to a 4 inch bore, that is only gonna give you .045 more clearance on one little section of the valve, a very small notch on the bore would do the same thing for free.
And 360 roller LA blocks are hard to find being only a couple years in very low selling rigs that were not always optioned with 360s. If you are willing to use magnum heads (you should) then finding roller blocks is real easy.
Any differance in a 318 stroker and 408 stroker is minimal, especially when you start looking for a roller block or even any block at all that is not free.
Re: 318 to 390? [Re: HotRodDave] #1315263
10/09/12 05:26 PM
10/09/12 05:26 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
I dont know Wade personally but I have seen this car and it certianly doesnt give you the impression it runs that fast.
https://board.moparts.org/ubbthreads/show...rue#Post6507721
Re: 318 to 390? [Re: Chris'sBarracuda] #1315264
10/09/12 07:18 PM
10/09/12 07:18 PM
California
Mad Dart Offline
Mad Dart  Offline
California
You might want to think that over carefully..
https://board.moparts.org/ubbthreads/show...rue#Post7384092
This was a 318/390..
Chris..
Unfortunately when a part fails like this it takes out the whole enchilada. This has nothing to do with the 318/390 build at all. I had the same thing happen to a hot 340 I had at 7200 RPM, Was not quite as bad but it did drop a valve, took out a cylinder, broke a pistion fkd up the head, annihilated a Rod. I could only find balled up pieces in the pan and all over the inside of the engine, intake etc. This can happen to any engine when a Valve lets go. I put a 410 Stroker in it and when I fired it off I had quite a few pieces come flying out the exhaust that were stuck in the mufflers.
Re: 318 to 390? [Re: Mad Dart] #1315265
10/09/12 10:49 PM
10/09/12 10:49 PM
Illinois
Tinmans21 Offline OP
Illinois
Idk if this makes a diffrence but the 318 actually came out of a 83 pickup. The motor is on a stand atm. Does anything change with that motor? It really sounds like its a matter of opinion or choice with the 318 vs 360 arguement. I'm going to stick with the 318 an stroke it to a 390 an bore the block .40 over. I'm going to stick with the 318 cuz i have a 383 block sitting soooo buying a 360 would just mean another motor sitting until I can sell it. I may plan on using nitrous for track use only permitting that the motor will handle it. The car will have a A833 for sure an a 8 3/4 axle for sure. Im new to this so any advice is appreciated. I am going to lighten the car as much as possible since it will see the track but i need to keep in mind it will also be a friday night cruiser. Thanks for all the input!!
Re: 318 to 390? [Re: Tinmans21] #1315266
10/09/12 11:16 PM
10/09/12 11:16 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
The '83 318 block is different than the older 318 blocks. The decks are weaker, and susceptible to cracking between the coolant hole and the nearest head bolt hole. I know this, because I was going to use a 1983 318 block to build a 390, and that block had a total of 10 cracks on both decks. They weren't discovered until after several machining operations. Here is a pic of what my engine builder found. Two differences you can see are the head bolt holes going through the deck, and larger coolant holes, both of which weaken the deck. On the older blocks, the head bolt holes are blind and the coolant holes are smaller.
I'm not saying your block WILL have these cracks, all I am suggesting is that you have those decks carefully examined before sinking money into machine work on that particular block. Also, have your machinist check for twist in the block. Seems the '83 blocks in general are on the weak side, which proved to be the case with mine. It was twisted pretty bad. Although my machinist informed me that the cracks could be fixed, I decided to cut my losses and start over with a beefier 1970 318 block that was available to me.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 318 to 390? [Re: DusterDave] #1315267
10/10/12 12:44 PM
10/10/12 12:44 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
'83 block is a non-roller block. personally, that's the big advantage of building a 318 based stroker over a 360, it's MUCH easier to find a roller cam block for cheap
2017 Grand Cherokee Overland
Re: 318 to 390? [Re: Tinmans21] #1315268
10/10/12 01:16 PM
10/10/12 01:16 PM
Delray beach, Florida
P
Performance Only Offline
P
My advice would be to bore it the least amount you can get away with, especially in a stroker application and your talking about spraying nitrous too. I've sonic checked a lot of blocks over the years, and 318's (among others) are not known for having thick cylinder walls.
machine shop owner and engine builder
Re: 318 to 390? [Re: Performance Only] #1315269
10/10/12 05:54 PM
10/10/12 05:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
My point about the 360 vs. 390 was purely cost related. You could get a running magnum 360 cheap. All of the rebuild parts are a wash between the two (gaskets, machining, etc…)
My opinion is that you can buy a 360 magnum motor for the price of a cast 318 stroker crank. So call that a wash dollar for dollar.
But if you're on a budget, I'd MUCH rather have a 360" with a 360 magnum head, then a 390" with a '83 318 smog head any day of the week.
It was more then just the cubic inch difference. Just depends how much money you want to spend…
Re: 318 to 390? [Re: dizuster] #1315270
10/11/12 01:14 AM
10/11/12 01:14 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
The OP mentioned using 360 heads at the start -
I agree that if you don't have the heads for a 392 - then its a different $ equation.
Re: 318 to 390? [Re: dizuster] #1315271
10/11/12 02:21 PM
10/11/12 02:21 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you can? here core 360 mags go for over $500, and runners are in the $800-1k range, even if they're over 120k miles...318 mags go for about 1/2 what the 360's do...
but yes, I'd much rather have a mag 360 and give up 30CID than a 390 stroker choked with LA 318 heads.
Re: 318 to 390? [Re: patrick] #1315272
10/11/12 06:09 PM
10/11/12 06:09 PM
Illinois
Illinois
Oh trust me i would never use the smog 318 heads on the 390 stroker. lol. Those heads would kill the motor. Im doing more research on the 383 big block i have. its a 68 with closed chamber heads. Stock cam no intake atm. The 318 may just go in so i can drive the car at least then work the 383. It would b nice to have 500hp to the wheels on a streetable car but im not sure if its possible. just more research must be done.
Re: 318 to 390? [Re: Tinmans21] #1315273
10/11/12 07:04 PM
10/11/12 07:04 PM
gregsdart Offline
gregsdart  Offline
If you don't open the hood the big block will make it a real sleeper. A LOT more cubic inches stroked, and stock heads with big valves and a little bowl work can flow enough to go over 500 hp. Probably with a hydraulic cam if you like.
Re: 318 to 390? [Re: patrick] #1315274
10/14/12 05:39 PM
10/14/12 05:39 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yup really... well based on my 15 seconds of searching anyway...
http://detroit.craigslist.org/wyn/pts/3337858380.html
Listed at $300 obo.
Re: 318 to 390? [Re: dizuster] #1315275
10/15/12 08:13 AM
10/15/12 08:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Listed at $300 obo.
nice price, but that's a 5+ hour round trip for me....
Re: 318 to 390? [Re: patrick] #1315276
12/16/12 11:01 AM
12/16/12 11:01 AM
Nowhere, USA
O
OUTLAW MOPAR Offline
O
Nowhere, USA
Go 390 stroker they make super impressive motors with correct parts. My darts 390 consists of a '71 318 block scat cast 4" crank scat H rods custom ross 9.5 blower pistons hughes hyd roller retrofit setup. Heads are Indy lax that flow 284 @ .550 w/ 2.02 1.60 and procomp airgap knockoff intake. Also has the awesome PRW. 1.6 Stainless roller rockers. This assembly was worth 457hp @ 6300 and 488 tq @ 4400 at the wheels. My buddy built a 360/414 shortblock same comp, heads, cam, intake, rockers he only bested me w/ 461hp @ 6300 and 490tq @ 4400 at wheels. Great motors but not much more for a ever harder to find '72 360 block which he paid $250 for when '67 to '75 318's are all but free like mine was cast was given by a local bowtie enthusiast. That bowtie boy aint real happy about being patty slapped by his cast away 318 from that rotted out powerwagon he scrapped.
