Testing alternator? Need some info! #1315135
10/04/12 07:11 PM
10/04/12 07:11 PM
Great Lakes State
O
ONEBADBIRD Offline OP
O
Great Lakes State
When I went to test the alternator, I put my tester (volt meter) on one of the electrodes on the back of the alternator (batt terminal) and it sparked! Then the motor bogged down a little then I pulled it off, does this present a bad ground or something else? Or is this normal? The battery while running is showing 13.5 and 14 volts, stock coil is about 3.75 to 4.25 volts while running. Thanks, Jay
Re: Testing alternator? [Re: ONEBADBIRD] #1315136
10/04/12 07:14 PM
10/04/12 07:14 PM
Great Lakes State
O
O
Great Lakes State
Converted to electronic ignition and all the boxes are grounded to the body, All electronics are 73 and up components. These are on an 69 road runner. Could my ammeter be part of the problem (original under the dash)?
Re: Testing alternator? Need some info! [Re: ONEBADBIRD] #1315137
10/04/12 08:24 PM
10/04/12 08:24 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
There are only 3 ways touching the + batt terminal on your alternator with a multimeter probe will cause a spark.
1. loose nut holding the batt wire eyelet connector to the B+ terminal and your probe moved it. Worth checking.
2. loose B+ post to alternator body causing intermittent connection to the alternator internals. (worth checking tho MUCH less likely. Wiggle it and inspect to see if the plastic washer is there. It's probably fine)
3. The MOST likely cause....is the test probe accidentally touched the alt case at the same time it touched the B+ terminal causing a short. I'll bet if you look closely youll find a small burn mark on the case of the alternator or your test probe.
4. Make that 4 ways... Just occured to me. Possible skinned or melted battery to alt wire meaning it was already near a sharp edge or heat souce so it didn't take much to bump it causing it to touch ground. Since I didn't see the spark and you didn't say exactly where it came from....I'm guessing.
My money is on #3. Tight work space - possible poor light- leading to operator error...
Try again.... Hold on a sec...lemme plug my ears just in case theres a boom... Ok Go for it....
Re: Testing alternator? Need some info! [Re: Dave440] #1315138
10/04/12 08:43 PM
10/04/12 08:43 PM
Great Lakes State
O
O
Great Lakes State
Thank you for the response! I am trying to figure out my electrical system and make sure everything is working together properly. Accidently touching the housing probably what happened, like you said operator error.
