engine install methods? #1314847
10/04/12 01:46 AM
10/04/12 01:46 AM
houston texas
gremlinsteve Offline OP
houston texas
who here has installed a engine / trans in there b bodies without the use of a lift? im reffering to coming in from the bottom on this.
having the motor and trans mounted to a k member anready
it will be my first time doing it this way and im thinking i can get it done with the use of a cherry picker or overhead hoist.
what say you smart guys?/
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: engine install methods? [Re: gremlinsteve] #1314848
10/04/12 01:48 AM
10/04/12 01:48 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's been done by lots of us. The first time I did it was because all I had was three floor jacks and no cherry picker and no help...
Re: engine install methods? [Re: Jim_Lusk] #1314849
10/04/12 01:50 AM
10/04/12 01:50 AM
houston texas
houston texas
any tips?
im thinking of making a cradle for the k member with rollers...something simple that i can roll.
Re: engine install methods? [Re: gremlinsteve] #1314850
10/04/12 01:55 AM
10/04/12 01:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I did it through the bottom but still used my cherry picker to do it.
Re: engine install methods? [Re: gremlinsteve] #1314851
10/04/12 01:56 AM
10/04/12 01:56 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
any tips?
$20 (or less) 1000lb furniture dolly from HF with a couple of 2x6 blocks does the trick.
Re: engine install methods? [Re: nomore65BelvJim] #1314852
10/04/12 02:01 AM
10/04/12 02:01 AM
houston texas
houston texas
awesome idea. i just bought you a beer....sometime in the future...i would have not thought about that.
steve
Re: engine install methods? [Re: gremlinsteve] #1314853
10/04/12 02:17 AM
10/04/12 02:17 AM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
I did it. I made a cradle and set the whole thing on that rolled it under the car, lowered the car then pulled the engine up with a cherry picker. The trans was mounted to. All by myself.
Re: engine install methods? [Re: gremlinsteve] #1314854
10/04/12 04:12 AM
10/04/12 04:12 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
steve
Re: engine install methods? [Re: 64Post] #1314855
10/04/12 04:57 AM
10/04/12 04:57 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
About 20 minutes to stuff a Hemi in an A-body. Just in time to get tacos for lunch!
Re: engine install methods? [Re: autoxcuda] #1314856
10/04/12 05:29 AM
10/04/12 05:29 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Know anyone with an ATV lift? Works great!
