K-Frame and Rear End:: Gloss or Flat Black?
#1314823
10/04/12 01:42 AM
10/04/12 01:42 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Any one out there have a good reference for what chassis, dana and other mechanical parts are suppose to be gloss black vs flat or satin, 1969 Charger?
I am ready to paint my K frame and under K frame shield and am having a hard time finding a reference.
There is also a black crossmember that goes behind the grill that bolts to the valvance, should that be flat black?
I have looked for a site or book with paint info on the B-Bodies and have not had much luck.
Thanks, CAC
Re: K-Frame and Rear End:: Gloss or Flat Black?
[Re: 69rrgrabber]
#1314824
10/05/12 07:54 AM
10/05/12 07:54 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Ok, I'm going to guess semi gloss on the k frame and dana, I read somewhere that the metal splash can under the frame is natural
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
[Re: a12rag]
#1314829
10/05/12 04:46 PM
10/05/12 04:46 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Just bought the Eastwood 2K Extreem Chasis Semi Gloss Black with primer kit. I've heard good stuff about it. I'll post the results. Still not sure on the color for the metal splash shield that goes under the frame and has the 1/4 rubber piece stapled to it. Found one article for a 71 Duster where the shop left it natural, but can't find a real reference. How come none of these "Mopar Restoration Guide" books ever give a break down on what to paint what? Guess it varied factory to factory. Thanks! CAC ![](/ubbthreads/images/graemlins/drive.gif)
1970 Cuda 440
[Re: 69rrgrabber]
#1314830
10/05/12 05:27 PM
10/05/12 05:27 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
OK, I know this is the 10th time I've said it but; - both parts were gloss black from the factory. Semi gloss was a GM thing. That having been said the cheapo factory gloss black wasn't exactly done with a high degree of quality in mind and it is easy to overdo it, using better materials, coverage and methods than the factory did...which is why Bill and others have suggested knocking it back from full gloss. ![](/ubbthreads/images/graemlins/Twocents.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1314831
10/05/12 06:54 PM
10/05/12 06:54 PM
Posts: 641 western australia
1cuda
western australia
i fully agree with the gloss black-but a lot of people look at the black on parts and because that gloss black is 40+ years old with nothing but weathering and being degreased and washed with all sorts it has now turned flat to semi gloss and people are trying to match that as a finish on a restoration. do them gloss but they were not a gloss black like the outside of a black car at sema- the paint was a brown/grey black and not like todays paints so the shine level is not a mirror black. anyway that`s my ![](/ubbthreads/images/graemlins/Twocents.gif) all the best frank.
[Re: 1cuda]
#1314832
10/05/12 11:26 PM
10/05/12 11:26 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Definitely a gloss black ring left under the K-frame bolt/washer.
[Re: DoctorDiff]
#1314835
10/06/12 03:10 PM
10/06/12 03:10 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To my eye, the only suspension part that was full gloss was the torsion bars; and they appear to have been dipped.
[Re: John_Kunkel]
#1314836
10/06/12 08:36 PM
10/06/12 08:36 PM
Posts: 352 Arizona
69rrgrabber
Arizona
I changed my order to Gloss Black which is 85% gloss. The semi gloss is 60 - 70% gloss. Its hard to compare apples to oranges as the materials have changed. Even if this is too glossy, after a few years it will be right, till a few years later, when it dulls!
Now if I could just figure out the color for the rest of my parts.......... torsion bars gloss black, Check. Would priming them make the paint too thick and crack the paint as they twist?
1970 Cuda 440
[Re: DPelletier]
#1314838
10/06/12 09:35 PM
10/06/12 09:35 PM
Posts: 2,295 Land of 10,000 Lakes
44D6PAKCUDA
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: DPelletier]
#1314839
10/07/12 10:19 AM
10/07/12 10:19 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
That's it. What needs to be considered is that the description for original "gloss" back in the day was just plain old gloss black, no flattening or dulling agents were used to reduce the shine. HOWEVER, the quality of the paint was an inexpensive industrial grade, and that it was applied in rapid fashion with no regard to the resulting appearance. It's purpose was a basic metal protection so the raw steel didn't rust immediately and likely as a mask so that the undercarriage didn't show when the car was being viewed from a few feet away. All this adds up to a duller looking black that you'd see on a finish painted surface such as the outside of the car painted with a higher quality paint. How do you reproduce the exact look of original? It's not as easy as it may seem, personally I'd clean the part to bare metal, prep it to "clean" status, spray a thin coat of primer sealer on, buy the cheapest single stage "gloss" black enamel and paint it on thin and fast and let it end up where it ends up.
*Most NOS K-members had a protective primer/sealer on them, usually a light or darker grey color, or rust red (depended on the era) but production line units may not have had any. Also, some early K-members (1967 and earlier in particular) were not gloss black! They were actually a very dark gloss gray, it looks black at a glance but sitting next to black it's a long ways away from black. ![](/ubbthreads/images/graemlins/Twocents.gif)
*Cass, I have no doubt that your parts are as described and certainly contribute to the knowledge base about original parts detailing, however, NOS/replacement parts were often finished differently than production line parts so you really can't use them as the final word in production line correctness.
