426 hemi fan clutch #1314357
10/02/12 04:23 PM
10/02/12 04:23 PM
Sacramento, CA
viperdude99 Offline OP
Sacramento, CA
Does anyone know where I can find a decent new/rebuilt fan clutch for a 426 hemi I'm doing right now? I know the originals are unobtainium so happy with something that will work that doesn't kill my wallet more than normal.. Any help would be greatly appreciated!
-Tony
Re: 426 hemi fan clutch [Re: viperdude99] #1314358
10/02/12 04:26 PM
10/02/12 04:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Auto parts store unit will work fine , or buy the MP viscous kit ?
Re: 426 hemi fan clutch [Re: JohnRR] #1314359
10/02/12 05:25 PM
10/02/12 05:25 PM
Sacramento, CA
Sacramento, CA
Thanks - I bought one from the parts store but the shaft is too long. interferes with radiator. I've seen the MP unit but I don't need the fan...
Re: 426 hemi fan clutch [Re: viperdude99] #1314360
10/02/12 05:29 PM
10/02/12 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do a search using the google search tab at the top of the page , there is a Hayden unit , think the application is for a Jag , that has a shorter shaft ...
edit , I can't remember if the MP unit is too big is some big block applications ?
Re: 426 hemi fan clutch [Re: JohnRR] #1314361
10/02/12 08:12 PM
10/02/12 08:12 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Great advise!
Re: 426 hemi fan clutch [Re: az426john] #1314362
10/02/12 08:34 PM
10/02/12 08:34 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I think the Jag short clutch is Hayden #2705 in the thermal and 1705 non-thermal. And I think there is an Imperial #211049 or 211043 that is only a little longer.
Master, again and still
Re: 426 hemi fan clutch [Re: DaveRS23] #1314363
10/02/12 09:10 PM
10/02/12 09:10 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
The 070 clutch can break the bank. Once you installed the other one you won't know the difference
MLR426
