Duel battery set-up? #1314098
10/01/12 09:15 PM
10/01/12 09:15 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
How is the correct way to hook up a duel battery set-up with a master disconnect? I think there is a way you can make it 24 volts so I wanna make sure I dont do that. Thanks guys.
Re: Duel battery set-up? [Re: Jonnyj00] #1314099
10/01/12 09:25 PM
10/01/12 09:25 PM
You must run them in parelel, both negatives together with a hard mounted #1 or #0 jumper cable and the same on the positive side I use RV/ Marine batterys that have the extra thumb screw terminal studs sticking up by the regular battery terminals I use female battery cable ends that I solder on the proper size ends, copper #1 or # 0 ends with 3/8 eye holes in them Those hook up to the thumb screws studs.
Re: Duel battery set-up? [Re: Cab_Burge] #1314100
10/01/12 09:56 PM
10/01/12 09:56 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
You must run them in parrelel, both negatives togther with a hard mounted #1 or #0 jumper cable and the same on the positive side I use RV/ Marine batterys that have the extra thumb screw terminal studs sticking up by the regular battery terminals I use female battery cable ends that I solder on the proper size ends, copper #1 or # 0 ends with 3/8 eye holes in them Those hook up to the thumb screws studs.
X 2, I ground both batteries to the chassis and T the positive cable.
Re: Duel battery set-up? [Re: Cab_Burge] #1314101
10/01/12 11:03 PM
10/01/12 11:03 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thanks guys does the master disconnect go to the positive or negative or does it even matter?
Re: Duel battery set-up? [Re: Jonnyj00] #1314102
10/01/12 11:18 PM
10/01/12 11:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Per the rules, the disconnect goes to the positive side. Even if it wasn't the rule, if you hook it to the negative side, weird things can happen.
2011 Drag Pak Challenger
Re: Duel battery set-up? [Re: rickseeman] #1314103
10/01/12 11:45 PM
10/01/12 11:45 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
This way works with a GM single wire alternator
