1966 Charger roof line pin stripe #1313761
10/01/12 02:51 PM
10/01/12 02:51 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
I can probably count on one hand the number of restored first gen. Charger that have the stripe put back on. I suspect that most people don't even know that they came standard equipment on the cars.
There is no info I can find about the color availability per exterior car color. The Ditzler color chip chart at the bottom only lists the stripe colors. There is nothing in the interior and upholstery info that I can find online.
Does anyone know of any factory info available that shows the suggested color of the stripe per the body color or did the factory just pick it themselves depending on body color?
Re: 1966 Charger roof line pin stripe [Re: 696pack] #1313762
10/01/12 02:55 PM
10/01/12 02:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Mine still has the stripe although I doubt its the original. Have you asked around on the 66-67 Charger sites? Good Luck with your quest.
Re: 1966 Charger roof line pin stripe [Re: bobby66] #1313763
10/01/12 02:58 PM
10/01/12 02:58 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Check w/Afterhours restorations,he has the info you need.
Leave the gun.......take the Cannoli's....Mike
Re: 1966 Charger roof line pin stripe [Re: 696pack] #1313764
10/01/12 06:28 PM
10/01/12 06:28 PM
I guess you know the original stripe was painted. As for the color, my 67 Charger was originally bright blue metallic with a navy blue interior and had a white stripe. Apparently three other stripe colors were available at least in the 67 model year (got this from Alaskan T/A's web site):
Edit: I see that this still doesn't answer your question, as it doesn't say whether any of the stripe colors were available only with certain of the body colors, or whether any body color could have had any color stripe.
Re: 1966 Charger roof line pin stripe #1313765
10/02/12 02:29 PM
10/02/12 02:29 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Yes, I had already checked there and I own a 1966 Dodge Dealer Data Book and they only mention it as a standard feature. I am guessing the info I seek was in the confidential dealer pricing and ordering info.
Re: 1966 Charger roof line pin stripe [Re: 696pack] #1313766
10/04/12 02:37 PM
10/04/12 02:37 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Anyone else have any info on this original post?
Re: 1966 Charger roof line pin stripe [Re: 696pack] #1313767
10/04/12 02:54 PM
10/04/12 02:54 PM
houston texas
gremlinsteve Offline
houston texas
mine was a original white car with blue interior.
she had a blue stripe.
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 1966 Charger roof line pin stripe [Re: gremlinsteve] #1313768
10/04/12 03:32 PM
10/04/12 03:32 PM
okla.
sam64 Offline
sam64  Offline
okla.
i hAD A PALE YELLOW,BLACK INT.THE STRIPE WAS WHITE,HAD A LIGHT TAN,WHITE INT.STRIPE WAS BLACK.
Re: 1966 Charger roof line pin stripe [Re: sam64] #1313769
12/11/12 03:15 PM
12/11/12 03:15 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Mine is a Black BB car, red interior and has a red pin stripe. Still on the car and will be replaced when it is repainted. It was noted on my Chrysler build card.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 1966 Charger roof line pin stripe #1313770
12/11/12 03:31 PM
12/11/12 03:31 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Thanks. That chart is not in the 1966 info on the same site.
There was a dark blue 66 Charger in my home town when new that had a red roof line stripe and although it doesn't SOUND like it would be appropriate it looked GREAT.
Re: 1966 Charger roof line pin stripe [Re: mike s] #1313771
12/11/12 05:28 PM
12/11/12 05:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The 66 my kid just scraped was an all OE car.It was black and had no stripe.Just solid black.It did have the black and white interior and had 50K original miles.Still have sheet metal left from it.Rocky
Chrysler Firepower
Re: 1966 Charger roof line pin stripe [Re: 696pack] #1313772
12/15/12 10:23 AM
12/15/12 10:23 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
When I sent to Chrysler for the Car Record card the information was decoded by Jon Gibbs on the 66-67 registry http://www.1966-67ChargerRegistry.com . We were trying to figure out the roof stripe and what my fender tag should look like. Here is what he told me " Hi Dennis,
Thanks for the quick scan. On the punch card, there are 80 rows and 12 columns when you orient it the long way top to bottom.
Columns are ordered like this: 9 - 8 - 7 - 6 - 5 - 4 - 3 - 2 - 1 - 0 - 11 - 12
If you look at row 61 out of 80, which is the row that goes through the 'U' in "POWER EQUIPMENT", you will see two punches. One in column 8, and one in coulmn 12.
This decides to an 'H' in the alphabet for red roof stripes.
12 & 1 is A
12 & 2 is B
12 & 3 is C
12 & 4 is D, etc.
So your fender tag should read BB1HQ under the PAINT section".
Hope this helps
