need fiberglass front fenders for 1970 Cuda #1313042
09/30/12 04:16 AM
09/30/12 04:16 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
I'm looking for fiberglass front fenders and front valance In order to improve the weight if my 1970 road racing Cuda.
What source would you recommend?
How much weight could actually be saved?
You can take a look at the car here http://www.hemicuda-france.com
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313043
09/30/12 01:03 PM
09/30/12 01:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
several sources, WS Racing in Ohio, VFN in Illinois, or Unlimited Products in California, they offer bolt-on and pin on glass, and some offer 1pc front ends, depending on how much weight your looking to cut
Re: need fiberglass front fenders for 1970 Cuda [Re: DAYCLONA] #1313044
09/30/12 11:36 PM
09/30/12 11:36 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
not unlimited
Re: need fiberglass front fenders for 1970 Cuda [Re: 05dakota] #1313045
09/30/12 11:44 PM
09/30/12 11:44 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
No matter what you do, stay away from Unlimited Products. If Unlimited was the last fiberglass vender on the panet, I would make my own parts out of squirrel urine and tree bark....
Re: need fiberglass front fenders for 1970 Cuda [Re: Ramrod39] #1313046
10/01/12 12:01 AM
10/01/12 12:01 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
So whats wrong with Unlimited,..I've purchased several fenders and hoods from them over the years, no issues, no hassels, granted like anything made in glass there's some work needed...
Mike
Re: need fiberglass front fenders for 1970 Cuda [Re: DAYCLONA] #1313047
10/01/12 03:03 PM
10/01/12 03:03 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
thanks for your hints and advices
What do you think might be the weight difference between a fiberglass fender and an original steel fender ?
Re: need fiberglass front fenders for 1970 Cuda [Re: DAYCLONA] #1313048
10/01/12 08:59 PM
10/01/12 08:59 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Mike
My transaction with Unlimited dragged on for months and was filled with out and out lies about when parts would be shipped, how parts had already been shipped (when they hadn't), how paperwork was lost, how I would have to call back later, how they would investigate and call me back later (they didn't) etc.
It got to the point that I actually kept a log of communications (read that as lies) with these folks by the phone. I even resorted to certfied mail to try to get either my parts sent or my money back. Worst vender I have ever tried to deal with in over 20 years in this hobby.
Re: need fiberglass front fenders for 1970 Cuda [Re: DAYCLONA] #1313049
10/07/12 04:56 PM
10/07/12 04:56 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
the 1970 repro grille @ http://www.vfnfiberglass.com/site.htm looks indeed like a cool piece for our racecar
Re: need fiberglass front fenders for 1970 Cuda [Re: Ramrod39] #1313050
10/27/12 09:17 AM
10/27/12 09:17 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Mike
Did you end up getting your parts or your money back ?
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313051
10/27/12 11:16 AM
10/27/12 11:16 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have seen a lot of good stuff on glasstek. so that is what im using, all holes have to be drilled, for mounting. i used all the factory mounting points.
as far as weight its about 50lbs removed.
you can loose another 50lbs by removing the door bars.
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313052
10/27/12 12:09 PM
10/27/12 12:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I wonder what a repro 70 Barracuda steel fender weighs compared to an original?
Also the cheaper chinese/south american front glass windshields are thinner and weigh less. Look for non-PPG front glass.
There is some no name reproduction side glass that is thinner too. Troy got some off E-bay for a 68 Dart that measured thin. Made in Brazil, IIRC.
One mans cheap reproduction parts are another mans trick lightweight race parts.
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313053
10/27/12 02:22 PM
10/27/12 02:22 PM
ca
N
nick24 Offline
nick24  Offline
N
ca
I bought fenders & hood from Unlimited for my '70 Cuda. Do yourself a favor, buy from ANYONE ELSE. Every piece was warped and misformed. The hood mounted 1/2" off center which produced a overlap on the driver's side and a 3/4" gap on the passenger's side. The gap between the fenders and the doors was over 2"! The hood scoop had spider web cracks all over. I probably should have taken it all back. Instead, I spent months making it right. I still have a trunk lid that is almost as heavy as a steel lid and I can't make it stay straight.....Want it?
Re: need fiberglass front fenders for 1970 Cuda [Re: nick24] #1313054
10/27/12 06:21 PM
10/27/12 06:21 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I sincerely doubt there is 50# worth of door beams, even in a E body. When I pulled the beams out of my '80, there were were maybe 10# each. Total removed added up to less than 20# when I was done.
There actually is a worse vendor out there than Unlimited. Two actually, but I think one of them is gone now. Showcars and MAS were definetly worse than Unlimited. The parts I got from Unlimited were not finished correctly, but they at least resembled the panels they were replacing. Not so much with Showcars glass. There stuff was so bad it made Unlimited look decent.
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313055
10/28/12 03:40 AM
10/28/12 03:40 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Mike
I finally got my money back through a challenge with my credit card company.
Re: need fiberglass front fenders for 1970 Cuda [Re: Ramrod39] #1313056
10/28/12 01:40 PM
10/28/12 01:40 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i too had a very bad experience with UNLIMITED.
Re: need fiberglass front fenders for 1970 Cuda [Re: bonefish] #1313057
10/28/12 01:54 PM
10/28/12 01:54 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
A friend of mine, who lives in LA, took a look at Unlimited, while on his way to SEMA. He said that there is one lady at the desk, who is also taking orders over the phone and then one guy in the shop, who makes the parts, but only works there part time, like four hous a day and not every day of the week. Chances are that they wait for enough orders to pile up and then hire the guy to build the parts. Their pricing is pretty low as compared too others. That would explain why they have way long lead times and poor quality.
Since my buddy agreed to check in them personally every other week, I'm taking the risk to place an order, but not for all parts.
I ordered the grille from VFN. They do also only start making the parts once they charged your CC and then also have a pretty long lead time of four weeks. Probably work on the same scheme.
Glastek sounds interesting. Do they have a website ?
The other alternative would be to these steel parts and make our own mold to duplicate fenders and valances in carbon fiber http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?preadd=action&key=MP-3443A
Re: need fiberglass front fenders for 1970 Cuda [Re: bonefish] #1313058
11/03/12 06:01 AM
11/03/12 06:01 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
I got my fenders, valances and front bumper from UP, thanks to my friend FuFu from Frog Specialties. FuFu was overseing the build from time to time and checking on UP. The parts look pretty good.
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313059
11/03/12 09:51 AM
11/03/12 09:51 AM
BDW Online content
BDW  Online Content
Please post what the weight savings is.
Re: need fiberglass front fenders for 1970 Cuda [Re: docford] #1313060
11/03/12 07:11 PM
11/03/12 07:11 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I assure you VFN is not a small 1-2 employee shop. I have been there, I have taken the tour. They make LOTS of fiberglass parts for all makes and models. They have an entire warehouse full of molds. They do NOT stock parts, they have no more room to store them.
I have had very good luck with the quality of parts from VFN and Glasstek. They are only about an hour from each other near Chicago.
My Cuda had a 1-piece front end, hood, doors, and deck lid all from VFN.
Too bad you are so far away, I have a pair of 70 glass Cuda fenders I would let go VERY cheap (not in very good condition or the best quality).
Re: need fiberglass front fenders for 1970 Cuda [Re: BDW] #1313061
11/06/12 05:00 AM
11/06/12 05:00 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
