2004 dodge intrepid problems..need help asap #1313020
09/30/12 12:31 AM
09/30/12 12:31 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
i have a v6 in the intrepid, heater hose from firewall was leaking so i replaced it, everything was good until i started up the car and a 9mm heater hose broke somewhere from the back of the motor and cannot find where it connects too, it has a plastic fitting inside the hose that connects to another hose is guess broke..i dont know where it broke from or where it goes any help would be greatly appreciated..
Re: 2004 dodge intrepid problems..need help asap [Re: bugsydog] #1313021
09/30/12 01:47 AM
09/30/12 01:47 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
I'm not real familiar with that motor the hose could connect with a hose under the intake that run to the front of the motor..
Re: 2004 dodge intrepid problems..need help asap [Re: BigTerry] #1313022
10/01/12 07:41 PM
10/01/12 07:41 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
is it the 2.7 or the 3.5?
Re: 2004 dodge intrepid problems..need help asap [Re: Dakota_Don] #1313023
10/01/12 07:54 PM
10/01/12 07:54 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i think there is a hose on the back side.. you might have to raise up the car, support with stands and get a good light and poke around, and thats on the 2.7..
