Re: tranny not up shifting help
[Re: backfire78]
#1313007
09/30/12 04:52 PM
09/30/12 04:52 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What kind of "manual valve body"?
[Re: John_Kunkel]
#1313008
09/30/12 07:32 PM
09/30/12 07:32 PM
backfire78
[Re: backfire78]
#1313009
09/30/12 07:39 PM
09/30/12 07:39 PM
John_Kunkel
Rio Linda, CA
If you put the shifter in 2nd does it take off in 2nd? If you put it in 3rd does it take off in 3rd? If you upshift from 1st directly to 3rd does it shift OK without lifting?
If yes to all the above, adjust your kickdown band.
[Re: backfire78]
#1313013
10/01/12 05:07 PM
10/01/12 05:07 PM
John_Kunkel
Rio Linda, CA
Once again, If you upshift from 1st directly to 3rd does it shift OK without lifting?
