Turn Signal Issue #131239
10/02/08 05:54 PM
10/02/08 05:54 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
When I have my turn signals on my 72 Roadrunner, and turn on my tail lights my turn signals go away. Any idea's Thanks
Re: Turn Signal Issue [Re: Moparmedic440] #131240
10/02/08 06:11 PM
10/02/08 06:11 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
May be as simple as checking the bulbs themselves. If that doesn't work, its time to start checking the wiring.
Re: Turn Signal Issue [Re: Moparmedic440] #131241
10/02/08 06:32 PM
10/02/08 06:32 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Gotta be more specific. Do they all not work, or just the fronts, or just the rears? If just the front or just the rear, check the ground. IIRC, the rear ground is inside the trunk near the left side marker. Could be loose or corroded. The front has two grounds, IIRC, they may both be loose, or corroded. If neither end works, may be combination of bad grounds at both ends.
More investigation and detail, and we can help you out more.
Good luck,
Marq
Re: Turn Signal Issue [Re: MoparMarq] #131242
10/02/08 07:14 PM
10/02/08 07:14 PM
This sounds like the classic case of no ground on the sockets
Re: Turn Signal Issue [Re: Moparmedic440] #131243
10/02/08 07:36 PM
10/02/08 07:36 PM
your turn signals work by themselves(both sides)correctly & the taillights work when you pull them out to the first click but at that point the turn signals stop functioning on either side? Since they are fed by seperate 12V inputs I agree that bad ground(s)& cleaning sockets would be a good 1st step.
