plastic straw in cylinder #1312327
09/29/12 10:44 AM
09/29/12 10:44 AM
central PA
mopartial Offline OP
central PA
I was spraying lube into small block cylinder for winterization and the little plastic straw fell off and into cylinder. Gonna be tough to fish out. Im thinking it would vaporize and get blown out of there on re-starting.
Anyone have thoughts on this?
If it aint broke, dont break it.
Re: plastic straw in cylinder [Re: mopartial] #1312328
09/29/12 12:41 PM
09/29/12 12:41 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
Don't start it!!! It will not vaporize instantly!!! It could hang a valve open a little bit and bend it when the piston comes up!!!
Re: plastic straw in cylinder [Re: mopartial] #1312329
09/29/12 01:19 PM
09/29/12 01:19 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
I did that before, on my mustangs 4.6.
I was able to take the plenum off and suck it out with a vacuum.
Re: plastic straw in cylinder [Re: 71sat440] #1312330
09/29/12 01:27 PM
09/29/12 01:27 PM
central PA
central PA
Ugh! I should have quit after fogging thru carb. This is in a bilge and hard to reach which is why it happened in the first place...this is not gonna be fun.
Anyway thanks for replies...
Re: plastic straw in cylinder [Re: mopartial] #1312331
09/29/12 02:59 PM
09/29/12 02:59 PM
I had that happen once & I ran it no problem. could duct tape the end of your shop vac down to a piece of vac line of the appropriate diameter & see if you could fish it out
Re: plastic straw in cylinder [Re: RapidRobert] #1312332
09/29/12 03:49 PM
09/29/12 03:49 PM
CrazyD Offline
CrazyD  Offline
Surgeon's forceps. I bought a pair at a swap meet, use them all the time to retrieve things out of tight spots.
Re: plastic straw in cylinder [Re: CrazyD] #1312333
09/29/12 04:19 PM
09/29/12 04:19 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You may get another straw just like it and see if brake clean or lacquer thinner or something like that will melt it. If so, you can then spray some of it in the cylinder to at least partially melt it and then run it to do away with the rest of it.
Master, again and still
Re: plastic straw in cylinder [Re: DaveRS23] #1312334
09/29/12 04:31 PM
09/29/12 04:31 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I would slowly bring it up to TDC (to get it as close to the hole as possible) then tape a hose to the end of a shop vac as mentioned and try to suck it out.
Good luck...
Re: plastic straw in cylinder [Re: bobs66440] #1312335
09/29/12 04:32 PM
09/29/12 04:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oh for pete's sake.
I once dropped a check ball from my carb down the plenum.
I said nuts to it and ran the 318, no problems and it's been over 10 years now.
Don't be the exception.
Re: plastic straw in cylinder [Re: Supercuda] #1312336
09/29/12 05:37 PM
09/29/12 05:37 PM
NJ
rth Offline
rth  Offline
NJ
Re: plastic straw in cylinder [Re: rth] #1312337
09/29/12 06:09 PM
09/29/12 06:09 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
The magic fingers gripper tool might do the job.
Re: plastic straw in cylinder [Re: John Brown] #1312338
09/29/12 10:14 PM
09/29/12 10:14 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you take take the springs of the valve and let it drop down youll have plenty of room to fish it out.
Re: plastic straw in cylinder [Re: bonefish] #1312339
09/29/12 11:44 PM
09/29/12 11:44 PM
God's Country Maryland
GODSCOUNTRY340 Offline
That little straw is not going to hurt the engine. Even if it does get hung up in a valve if your valve springs aren't strong enough to crush that little tube of plastic you've got other problems. Start that sucker and let it melt away!
Re: plastic straw in cylinder [Re: Supercuda] #1312340
09/30/12 08:14 AM
09/30/12 08:14 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Oh for pete's sake.
You're making that up, aren't you.
Re: plastic straw in cylinder [Re: Commando1] #1312341
09/30/12 09:24 AM
09/30/12 09:24 AM
scratchnfotraction Offline
Oh for pete's sake.
I had a 1/4-20 nut fall down an intake runner,fired it off and it made a heck of a noise till it spit it out the header. sounded like the rattle ball in a can of paint while idling.
didnt seem to hurt anything,ran it for a few yrs after that. when i R&R the head it looked like a shotgun blast with birdshot.
thousands of small nicks in the top of piston but none on the head or cyl. exhast vale had normal carbon pitting.
so maybe he is not makeing that up.
with the plastic straw??? I would think it would melt and not damage anything.
but then again the melted plastic could get into the ring land and stick a ring in the groove or something like that.
do you feel lucky? then roll the dice.
if in doubt??? get it out.
Re: plastic straw in cylinder [Re: scratchnfotraction] #1312342
09/30/12 11:26 AM
09/30/12 11:26 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I've had a few valve seals make the journey to the bottom of the pan...No harm done.
[image][/image]
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: plastic straw in cylinder [Re: scratchnfotraction] #1312343
09/30/12 12:01 PM
09/30/12 12:01 PM
that's what I was thinking would be a worst case scenerio tho IMO it'd likely just burn up but I would fish or vacuum it out (1) for peace of mind and (2) to accept that mistakes do happen (Murphys law) and (3) that you have the skill to rectify any adversity that does comes your way (cause it wont be the last). Holler how it turns out
Re: plastic straw in cylinder [Re: mopartial] #1312344
09/30/12 01:23 PM
09/30/12 01:23 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
I had the camera from an inspection camera get chopped off in a cylinder when my neighbors kid saw the pretty red button hanging off the side of the car and pushed it. It was a remote start button and I had the camera in a cylinder of my brand new engine. I thought about leaving it in there after trying to get it out for a day and a half but decided no to.
I was able to get it out by rolling the motor over until the piston was all the way up the camera would roll down just below the spark plug hole I took a plastic art paint brush and put a little gorilla snot ( 3M weatherstrip adhesive ) on it poked around a few times but finally stuck to it and I got it out. A plastic straw would be easier because it will bend a little to get it out of the plug hole. The camera only fit out of the hole one way so it took some time to get lucky.
I would be inclined to just leave the plastic straw in there I would think it would melt and burn up turning to harmless ash the will come out of the exhaust. I think this is a coin toss situation.
Re: plastic straw in cylinder [Re: Commando1] #1312345
09/30/12 02:01 PM
09/30/12 02:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oh for pete's sake.
Nope, serious.
Heck, it was "just" a 318 and I had a 360 on the stand as back up anyway and it would have been just as easy to swap engines as it would have been to pull both heads looking for it.
Years later I swapped the 318 into another ride (still have it) and I pulled the heads to look. A few little divots in the top of the piston is all.
Re: plastic straw in cylinder [Re: Adobedude] #1312346
09/30/12 02:38 PM
09/30/12 02:38 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
what kind oilpump you usin,i want one.i tiny little shard trashed mine.
