hemi water pump housing # #1311993
09/28/12 11:54 AM
09/28/12 11:54 AM
OH
junkyardmaxie Offline OP
OH
have couple water pump housings were wodering if anyone could check the numbers for me ? hemi ? 2205862 the other last 3 are 987 thanks
Re: hemi water pump housing # [Re: junkyardmaxie] #1311994
09/28/12 12:19 PM
09/28/12 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only hemi specific waterpump housing was on the A990 and possibly the 68 A bodies and it's made of aluminum .
Not sure about your early number but a 987 housing will be found on all big blocks .
Re: hemi water pump housing # [Re: junkyardmaxie] #1311995
09/28/12 04:01 PM
09/28/12 04:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
According to an old NHOA chart, the 2780987 casting number housing was used on '67-'71 Hemi's. '66 used 2468007. Earlier than this is a real mish mash.
Re: hemi water pump housing # [Re: 6PakBee] #1311996
09/30/12 01:37 PM
09/30/12 01:37 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Thanks for the information. I just went out and checked the casting numbers on a water pump housing I have in storage and it is 2468007. I was going to give it to a buddy of mine to use on a 440 car, but I think I will keep it now.
Re: hemi water pump housing # [Re: az426john] #1311997
09/30/12 08:25 PM
09/30/12 08:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just an FYI it's NOT a hemi Specific housing, neither is the other one .
Re: hemi water pump housing # [Re: JohnRR] #1311998
10/01/12 12:47 AM
10/01/12 12:47 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
.. If it needs to be a correct date code, that would be the only concern..
The 220XXXXXpn is for a '62-'63
Re: hemi water pump housing # [Re: 52savoy] #1311999
10/02/12 11:47 AM
10/02/12 11:47 AM
Arizona
az426john Offline
az426john  Offline
Arizona
Thanks guys.
The water temperature sending unit is in the wrong place for a 69 so we will find him one for a 67 - 69 "B" motor. It is for the infamous "General Lee" conversion so no date coding required. It is already built from parts so it is bad enough already.
Thanks for your continuing support.
