Re: Heat soak?
[Re: tboomer]
#1311934
09/28/12 11:19 PM
09/28/12 11:19 PM
Posts: 7,506 Az
Crizila
Az
Best insulator is wood. Next is phenolic. When it comes to heat soaking problems, heatshields don't work. They actually become heatsinks and can make the situation worse. Remember, the heat isn't coming from the carb, but from the engine. They were originall intended to keep hot air away from the carb while the vehicle was in motion - and it was questionable how well they worked in that application - although a million of them were sold.
Fastest 300
