Valve Covers for 472 Crate Hemi
#1311822
09/28/12 04:05 AM
09/28/12 04:05 AM
Posts: 142 Petaluma, CA
JimDiesel
Petaluma, CA
Car is a 1968 Road Runner with V8 K and conversion mounts Engine is 472 crate hemi from mopar,
I have two sets of valve covers that don't fit.
The first set is cast aluminum stage V, but they hit on the passenger side fender well where the shock mounts.
The next set is a stamped steel original style black wrinkle finish that has a splash guard on the inside that hits on the valve train on the drivers side.
I assumed that 426 covers would clear on a 472.
Anyone have any experience with this?
My current plan is to remove the splash guard and see if that give enough clearance.
68 Road Runner 67 Coronet
Re: Valve Covers for 472 Crate Hemi
[Re: 3ddart]
#1311826
09/28/12 09:18 AM
09/28/12 09:18 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
common problem with cast valve covers, especially on ebodies. as said earlier try to move the motor over as much as you can. also see if you can lower the engine. see if you can find shorter valve covers, the taller the valve cover gets the worse it will hit.. if all of the above will not work you might have to modify the shock tower to clear the valve cover.
here is a pic of a modified ebody shock tower.
perception is 90% of reality
[Re: Mr T2U]
#1311827
09/28/12 09:19 AM
09/28/12 09:19 AM
Mr T2U
un-modified other side for comparison. i also flattened the upper control arm bumps to add clearance for headers.
[Re: scottk]
#1311829
09/29/12 05:28 AM
09/29/12 05:28 AM
JimDiesel
Petaluma, CA
thanks for feedback. I will see if I can remove the breather splash guard in the steel valve covers to get the clearance I need on the valve train. Seems easier than modifying inner fenders at this point.
[Re: scottk]
#1311830
09/29/12 09:24 AM
09/29/12 09:24 AM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
Yeah it can be tight in there. Here is a pic of the passenger side in my wife's challenger.
lol.. i remember dropping the body down over that motor.. boy was that a tight fit...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
