Re: fixed ignition timing loss with rpm issue
[Re: mopar dave]
#1311700
09/27/12 09:40 PM
09/27/12 09:40 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i would say that MSD is correct. you have to keep in mind that any time you have clearance between the drive gear and the cam, up and down clearance between the drive gear and the cam and a camshaft that can move front to rear and back to the front (depending on the set end play as well as any play a timing chain might have, you'll always have the potential for the timing to move around a little bit. the magnetic pickup itself will not cause timing to retard. after all, the crankk trigger is also a magnetic pickup.
machine shop owner and engine builder
[Re: mopar dave]
#1311702
09/27/12 10:34 PM
09/27/12 10:34 PM
Performance Only
i'm glad to hear the crank trigger fixed your problem. as far as the distributor being the problem, we'll just agree to disagree. intetrmediate shaft is able to move up and down and the cam walks front to rear changing the gears position of rotation which effects the position of the rotor/ reluctor to magnetic pickup, as well as the other things i mentioned. more often that not the drive on the distributor has some play where the tang fits the intermediate shaft as well. all of those things can add up to a considerable amount of timing change. unless something is loose inside the distibutor itself, it's not likely the cause of your problem on its own.
