B-Body BENCH SEAT belt location? #1311557
09/27/12 04:03 PM
09/27/12 04:03 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
This is so simply I'm almost embarassed to ask. On my 70 Roadrunner front bench seat - aren't the center belts (the ones attaching to the tunnel) supposed to go THRU the lower seat upholstery as opposed to just lying on top of it? The belts have a plastic grommet bezel thing and I'm about ready to stick a knife thru the new seat cover but... I'm sure someone here has an answer and/or photo to help me out. Thanks in advance... Mike
Re: B-Body BENCH SEAT belt location? [Re: MCTPhoenix] #1311558
09/27/12 04:12 PM
09/27/12 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
THROUGH , the upholstery ... Not that I know of or ever seen .
Re: B-Body BENCH SEAT belt location? [Re: MCTPhoenix] #1311559
09/27/12 04:33 PM
09/27/12 04:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
on my 69 the belts just lay between the bench and the back (correct??) i believe on a 70 they went through it and there are plastic oval pieces that cover the slit.
Re: B-Body BENCH SEAT belt location? [Re: mikemee1331] #1311560
09/27/12 04:35 PM
09/27/12 04:35 PM
Phoenix, AZ
Phoenix, AZ
Yes, I've got those plastic oval shaped bezels on my belts and don't know where to slice the seat.
Re: 1970 B-Body BENCH seat belt HOLE location? [Re: mikemee1331] #1311561
09/27/12 07:38 PM
09/27/12 07:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
True , most the cars I parted were 68/9 , I did do a low mileage 70 but don't remember if it was or not .
