318 LA to 360 Magnum Swap #1311411
09/27/12 10:15 AM
09/27/12 10:15 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline OP
I have a tired 1972 318 LA in a 72 B-body (originally a 318/904) that I would like to swap out to a late 90s 360 magnum and keep the 904. I’ve searched the tech articles and forum, have found pieces of information regarding such a swap but not a complete run down so I would like to ask about the following and if I have it right.
I’m tried to do this as cost effectively, i.e. cheap, as I can but still being realistic.
Engine Mounts – Schumaker’s conversion mounts are the easiest way to handle this.
Oil Pan – crate version 360 magnum oil pan and one piece gasket.
Camshaft – keeping the stock camshaft but also the mechanical fuel pump so I need the Hughes Engines adaptor, http://www.hughesengines.com/Index/produ...mp;partid=22194
to use the eccentric.
Timing Chain Cover and Accessories – I’m keeping the timing chain cover and accessories from the 318. First to use the mechanical fuel pump and the 360 I’m looking at doesn’t have any accessories.
Intake – Re-drill the magnum heads for an LA 340 intake.
Carb – Small block early 70s Thermoquad.
Kickdown Linkage – Can use stock 4-barrel linkage with the stock intake, TQ and A904.
Exhaust Manifolds – 340 manifolds with Remflex gaskets to take care of the Magnum’s raised ports possibly causing a leak with the manifolds.
Flexplate – Get a 96-02 360 Magnum flexplate since it has the weights already. The 904 torque converter is already neutral balanced.
904 – Stock rebuild, nothing out of the ordinary.
Starter – Stock mini-starter.
Valve Covers – reuse the 318 valve covers to keep the 360 looking stock, period correct, etc.
Thanks in advance for any help,
Mike.
Re: 318 LA to 360 Magnum Swap [Re: moparmike1] #1311412
09/27/12 11:29 AM
09/27/12 11:29 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Magnum motor doesnt have a mechanical fuel pump or place to stick one so you are going to need to improvise there.
Re: 318 LA to 360 Magnum Swap [Re: moparmike1] #1311413
09/27/12 11:31 AM
09/27/12 11:31 AM
Andrewh Online content
Andrewh  Online Content
Engine Mounts – Schumaker’s conversion mounts are the easiest way to handle this. or you could reuse the 318 mounts and use spacers on the drivers side(I think) to take up the extra space.
not the cheapest way, any 360 la pan works, and apparently they make a 1 piece la gasket now. but not sure it is a big deal if you can't find it.
unless you already own it, the crosswinds are pretty cheap for carb.
durango manifolds worked in an early b for me. should be fine in a later b, should be pretty cheap too, again unless you aready have the manifolds.
2 things here. I don't think you can use the stock flex plate since the screws to hold it on are spaced differently than the stock 904 torque converter. in addition, I think you have to hvae a 96 and up magnum to make that work. B&M made one for the 727 and you could slot a hole for the 904, but I never tried, so cannot say.
Mike.
Re: 318 LA to 360 Magnum Swap [Re: Andrewh] #1311414
09/27/12 02:11 PM
09/27/12 02:11 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
on the cam, if you can find a mid/late 80`s v8 CAR diplomat/gran fury/ect. with a 318 grab the cam out if that, its a roller and you wont have to buy the adapter(which i have heard of at least one failure with this part). the last roller cam i got out of the junkyard was $20. it will have about a .417 lift(more that the truck cam if i remember right) with the 1.6 rockers. reuse your roller lifters on the long snout cam.
Re: 318 LA to 360 Magnum Swap [Re: moparmike1] #1311415
09/27/12 05:46 PM
09/27/12 05:46 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Also consider that you need a damper/balancer and it MUST be from a 5.9. 360LA has different balance from Maggie, so don't try to use one of them either. Also, late in the 5.9 run teh damper and lower pulley became a 1-piece assembly (and serpentine, of course).
You could always use a $35 square-block electric pump as you're going carb.
Whatever yu do, teh V-belt and Maggie front accessory drives must almost always be kept intact as a whole system. Mix-match of parts will cause headache.
Using an LA roller cam was mentioned:
Mags oil the rockers individually thru the rockers, so you must use Mag lifters & hollow pushrods. The LA cam will have 2 oiling holes thru 2 journals, I can't remember if using an LA rolelr in a Mag block causes any trouble, though.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311416
09/28/12 01:43 AM
09/28/12 01:43 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
How does that cam snout extension fail if the bolt is torqued correctly?
I've used a few of them the first one I bought has almost 100k on it
The Crosswinds intake is the only intake that you can actually use all the original V-belt stuff & hoses that any parts counter guy can find easy
The LA 360 pan will fit (the most I've paid for one lately is $50
Mag motors till 99 had bolt on bottom pulleys
Re: 318 LA to 360 Magnum Swap [Re: BulletBob] #1311417
09/28/12 08:49 AM
09/28/12 08:49 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I wondered that too. Combination of high RPM and higher-ouput fuel pump, maybe? And maybne not torqued properly so teh clamp force between button & cam was low, causing the little key to carry more load?
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311418
09/28/12 11:03 AM
09/28/12 11:03 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i`m not sure how it fails but i`m pretty sure i saw a video posted on moparts showing the failure.
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311419
09/28/12 11:11 AM
09/28/12 11:11 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
There is one more issue that needs addressing. Maybe someone who has done this before can help out. The bracket on a 1999 5.9 mangum is different than the earlier 360's. This requires an alternator that is different to what we are used to also. As I am converting a 87 Dakota v6 over to the 99 5.9 mangum, I have done most of the work and can help some. The big problem now is the alternator. It apparently has an internal voltage regulator that is incompable with the voltage regulator we use in the older cars. The 87 has the standard exterior voltage regualtor. So, now the internal regulator is fighting the external regulator. Any ideas on how to fix this?
Re: 318 LA to 360 Magnum Swap [Re: warpspeed] #1311420
09/28/12 11:15 AM
09/28/12 11:15 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
An internally-regulated alternator can't be wired to an external regulator.
The blue wire to the ext regulator is the ign wire and should go to teh new alternator somewhere. The green wire between old alt and old reg can be deleted.
But...
Weren't some of these alts regulated by the engine ECU? Or is that post-Maggie?
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311421
09/28/12 11:21 AM
09/28/12 11:21 AM
I am not sure what you mean by 99 and up alt being different.
I have a 2000 5.9 from a durango, and used the alt out of an earlier dakota and it worked fine. the alt is the same from like 96 to 02 if you look on line.
as for the vr, I am using a pre 70 single field vr on mine. no issues.
ground 1 wire and the other is wired to the vr like any dual field vr.
don't know of any mag engines using an internal regulated alt. they were all computer controled.
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311422
09/28/12 03:16 PM
09/28/12 03:16 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
that's what I needed to know. The newer alternators have a internally voltage regulator and are controled by a cpu, right? My 87 Dakota uses the external regulator. So, as I am starting up the engine, I am beginning to think that the wiring on the "new" (that is, the 99 alternator) won't work with the old style "external" regulator. So, you say the blue is ignition, green is not used. You can't just cut those off completely. It has to run to the alternator some how to turn it off and on to keep the voltage going to the battery doesn't it. Does it have to have the cpu, or can I remove the internal regulator and keep the old setup? Anyway, do you see where I am going?
Re: 318 LA to 360 Magnum Swap [Re: Andrewh] #1311423
09/28/12 03:22 PM
09/28/12 03:22 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
This!
when I went carb'd bigblock on my 98 Dakota, I used the stock alternator that was on the V6 in the truck originally. wired it up to a 1970s style VR and it worked fine.
For awhile, I thought I was running at 16 volts with RPM and 14v at idle, and thought maybe I had voltage drop issues in one of the sense wires or that the VR was bad. I eventually put a voltmeter on the battery itself and saw that I was really getting about 12.5 at idle and 14.5 with RPM.
**Photobucket sucks**
Re: 318 LA to 360 Magnum Swap [Re: Andrewh] #1311424
09/28/12 03:23 PM
09/28/12 03:23 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Andrew, that would be the better way, maybe? But, I have the 99 magnum engine and it's water pump, and alternator bracket with the single serpentine system. Therefore, I used the 99 alternator that fits that bracket system. That is an internally controlled alternator. Now the question is whether it needs the cpu or can get by with just the wiring, going to it with the electronic box that mounts on the top of the alternator. Maybe that is all that I need to make it work.
Re: 318 LA to 360 Magnum Swap [Re: warpspeed] #1311425
09/28/12 03:32 PM
09/28/12 03:32 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
EDIT: a few more responses came in while I typed this, not sure if I helped or not.
Not having a schematic for this, we'll need to talk in generalities.
External:
Blue was ign wire, went to alt and Vreg. Green goes from Vreg to alt and turns the alternator field on/off. Mid-60s had 1 field, later ones had 2 fields.
Internal:
Ign wire must go to alternator for reference, then the Ireg switches teh field as needed.
However -
The Mag style is external but triggered by the ECU. Without a schematic, or info from someone who has done it, anything else is just guessing. It could be triggering the alt via + or -, and to teh field or input voltage.
Both:
For both styles the heavy 12-10 ga cable is what is used to keep system voltage up by filling teh battery. That +/- voltage comes across the blue wire and the Reg reviews it again to decide whether to cycle the alt fields.
You might try browsing 'madelectrical' and see if they have further info.
Re: 318 LA to 360 Magnum Swap [Re: warpspeed] #1311426
09/28/12 04:22 PM
09/28/12 04:22 PM
I think you need to show a part number or picture of this 99 internal alt. Mine is a 2000 mag and it was externally regulated. So I am not sure which alt you have, and have never heard of one like that.
For mine, I used the plug coming out and wired it like I would any dual field alt. 2 wires came out. one went to ground, the other went to my vr output.
Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311427
09/28/12 04:53 PM
09/28/12 04:53 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Just had an order come in heere at work that is taking my mind and time. Have to complete it before getting back to you and Andrewh.
I will disgust this and reveiw. I am going to look at the 98 setup and see if it is the same. Anyway, I am under the impression that the 99 is internal. It is doing some weird things the way I set it up. But, I am using the 87 VR (external). the ground is good, so that isn't the problem. It runs up to 17 to 18Volts and then drops back to mid volt. And the battery went dead really fast while I was testing it in the yard.
Re: 318 LA to 360 Magnum Swap [Re: Andrewh] #1311428
09/28/12 05:10 PM
09/28/12 05:10 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Okay, Andrewh, looked up the alternator on Autozone website. It indicates that their alternator is external regulator. I will check it again and make sure the regulator is good. Thanks ya'll
Re: 318 LA to 360 Magnum Swap [Re: warpspeed] #1311429
09/29/12 07:51 AM
09/29/12 07:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
sounds like you figured it out...check out that wiring.
I do know that in 99 they changed the design of the alternator ever so slightly. the 98 ones use "old school" nuts on a stud to hold the field wires to the alternator.
but, that requires a wrench to remove the field wires, plus the grounds to the alternator case. in 99 they changed those wires to a quick disconnect plug like the rest of the engine harness, which is why it probably gives the appearance of being a "one wire internal regulated" alternator.
Re: 318 LA to 360 Magnum Swap [Re: 70Cuda383] #1311430
09/30/12 03:17 PM
09/30/12 03:17 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use the alt brackets from a 91 van with a Denso to use the newer alt it's for v-belt accessories & when bolted iup looks like that older car\truck came factory with it
