WHO USES BEADLOCKS???
#1311231
09/26/12 10:55 PM
09/26/12 10:55 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Who's using them and why?Single or double? Post a picture if you can. I have a bent rim and need to replace,so looking at beadlock rims.Whatcha got??
Re: WHO USES BEADLOCKS???
[Re: go green]
#1311239
09/27/12 01:18 AM
09/27/12 01:18 AM
hemi-itis
Al & Mark,you bought holeshot rims and had champion do the beadlock machining??I like the pentastars in those rims.
[Re: hemi-itis]
#1311241
09/27/12 01:20 AM
09/27/12 01:20 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
My car dont make enough power for doubles Yes Holeshot wheel and beadlocks dont by Champion.
[Re: EvilB1Dart]
#1311244
09/27/12 02:06 AM
09/27/12 02:06 AM
Posts: 299 Sparta, TN
mark42202
Sparta, TN
Al, firstly I bought my Holeshots and they had the beadlocks done before they shipped them to me by Champion. Secondly, I should have worded it differently. It's not that they CAN'T be used on the street, but personally, my two rears with double beadlocks cost just north of $2000. You said you have a bent rim now. I cringe to think of one of my rears getting bent from driving on the street. Just my opinion, though, lol. I know you drive yours more on the street than anything, so your situation is a little different than mine. I would just be SUPER careful, just because of the cost. Nothing else.
[Re: mark42202]
#1311245
09/27/12 02:17 AM
09/27/12 02:17 AM
hemi-itis
So a single beadlock and screws on the inside or just get the doubles?My friend joe just bought these champ singles.
[Re: hemi-itis]
#1311246
09/27/12 02:21 AM
09/27/12 02:21 AM
Al_Alguire
Las Vegas
Be aware they ad a fair amount of weight to the wheel. Really about the last place you want to ad it. But I guess if it is cheaper than replacing a bent wheel why not...I would keep an eye on the fasteners for sure if you plan on driving it.
As to the question of single or double. Be aware that certain width and offsets will interfere with rear brake calipers. If youhve discs on back.
[Re: hemi-itis]
#1311247
09/27/12 02:26 AM
09/27/12 02:26 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Al,
The doubles cost more, but make it a little easier to remove/replace tires. Using the singles you have to still get that backside bead seated, but not hard to do. You'd be just fine with singles and screws. Your choice.
I assume your car has rear discs brakes? If you're gonna go with doubles make sure you inform the beadlock manufacturer what type rear brakes/calipers you are using. Some backside beadlocks will not clear the rear calipers (mainly the older style Wilwoods) without the backside beadlock inside area or calipers being slightly modified.
[Re: EvilB1Dart]
#1311248
09/27/12 10:26 AM
09/27/12 10:26 AM
Posts: 2,653 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I use beadlocks but I don't think you would want to. Beadlocks are super heavy and expensive. Beadlock tires are heavy and expensive. It's one of those things that you think is neat till you get them. If I can't talk you out of them, get double beadlocks.
2011 Drag Pak Challenger
[Re: rickseeman]
#1311249
09/27/12 10:49 AM
09/27/12 10:49 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I would like to get my Magnum 2.0's bead locked after watching a you tube video of a high horsepower 28x10.5 car without them almost pulling the tire right off of the rim at top end from the tire growth. Seems like different manufacturers have different specs as to what back spacing & off sets can be done. Guess i need to call Weld to verify if mine can be done or not.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: rickseeman]
#1311250
09/27/12 10:52 AM
09/27/12 10:52 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Beadlock tires???? I use the same tire either way. are they heavier yes, do you need them well maybe but they do make mounting a breeze, they clamp the tire better and they look cool as [Edited by Moparts - Family Friendly Site - Keep it clean].
Another thing i do is when i buy them from weld i get one set of rings polished and the ohter anodised so i can switch up the look. The dart ones have gold and ppolished rings my regal has black and polished.
Also, Mine were all existing wheels sent back to weld to get bead locked
here is a picture of my regal ones with black rings on the outside and polished on the inside:
and here is a picture of the dart ones we picked the gold this time around:
BB, TT5,Procharged 3300lb Street Car 4.79/154
