interior insulation material...besides dyno mat.. #1311197
09/26/12 08:23 PM
09/26/12 08:23 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Does anyone know what the product name is for a sound deadening mat that is blue\denim in color with a one sided foil type backing? I its used allot in audio type work. Needing some before I lay in the carpet on the RR.
Or know of a cheap, but similar material?
Chris
Re: interior insulation material...besides dyno mat.. [Re: cdp] #1311198
09/26/12 09:05 PM
09/26/12 09:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rattle trap from fatmat.com
Re: interior insulation material...besides dyno mat.. [Re: cdp] #1311199
09/26/12 10:07 PM
09/26/12 10:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to a mobile home supply and get roof flashing, almost like dynomat but a roll that is 3ft by so many yards is less than a hundred dollars. Can do a lot of cars with that.
Re: interior insulation material...besides dyno mat.. [Re: 71birdJ68] #1311200
09/26/12 10:50 PM
09/26/12 10:50 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I've read pro's and con's on the Lowes product. Mainly an odor issue...like tar or something.
I helped my brother encase the whole outside of his basement with a thick stick on membrane. Man was that stuff sticky.
I did find this while surfing. Price is bit higher, but you get allot of it.
http://www.raamaudio.com/products/RAAMmat-BXT-II.html
Thanks for the link, it also looks like a good place to start.
Re: interior insulation material...besides dyno mat.. [Re: cdp] #1311201
09/26/12 11:20 PM
09/26/12 11:20 PM
Vancouver, BC, Canada
rtriv Offline
rtriv  Offline
I did a bunch of research on this a while back and ended up getting the RAAM stuff plus the ensolite. I wanted a butyl based product as opposed to the asphalt stuff. The RAAM was the best bang for the buck I and I was really happy with it.
