Narrow the rear or get another housing? #1311146
09/26/12 06:20 PM
09/26/12 06:20 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
My '72 Dart has had the leaf springs moved into the frame rails, and minitubbed. It came with a B-body rear (60-1/8" drum to drum) with new spring perches already in place, and old stock-sized tires and wheels for rolling it around. I plan on either 295-60R15 or even 325-50R15 if they'll fit in there. 451, 4-speed, mostly street use.
I got a great deal on Moparts for a pair of steel wheels widened to 10" with 8" backspacing, figuring on the sleeper look and that would be enough backspacing to use the B-body rear as is. Unfortunately it's not.
The outer edges of the rims, even with that maximum possible backspacing, is just about even with the unrolled inner fender lip. And there's miles of room between the inside of the rim and the frame rail (actually more like 4" but I haven't measured it yet).
So it looks like I either have to narrow the rear about 1.5 - 2" per side, which means new axles before I can even roll the body around, or get an A-body rear and run it stock for a while. I'm on a budget here so a Strange 60 is not really an option
Narrow the B-body or get an A-body rear?
single choice
Votes accepted starting: 09/26/12 05:18 PM
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311147
09/26/12 06:54 PM
09/26/12 06:54 PM
scratchnfotraction Offline
how long are the axles you have from flange to spline end?
over 30" ?
Re: Narrow the rear or get another housing? [Re: scratchnfotraction] #1311148
09/26/12 06:56 PM
09/26/12 06:56 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Narrow it. Probably cost the same as buying an A body housing.
An A body rear isn't going to have BBP axles unless you find one already converted.
Re: Narrow the rear or get another housing? [Re: RobX4406] #1311149
09/26/12 07:12 PM
09/26/12 07:12 PM
West Plains, MO
West Plains, MO
Don't know about the axle lengths, haven't pulled them. Why do you ask - axles long enough to be cut down without resplining?
Thanks for the reminder, I forgot about that! Now to find a shop in southern MO or northern AR that has the proper jigs for an 8-3/4...
Re: Narrow the rear or get another housing? [Re: RobX4406] #1311150
09/26/12 07:13 PM
09/26/12 07:13 PM
if he could find another stock housing a little narrower than what he has and a set of stock axles for it.
it could work out better than a cutdown/respline/after market or A-body thats converted to BBP.
I have a housing and a set of axles that are thick 30" long BBP.
my moser A-body axles are 28" long.
this is why i was asking how long are the axles he has are.
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311151
09/26/12 07:17 PM
09/26/12 07:17 PM
Dr Diff is out your way. check with Cass he is a great member for axle work.
Re: Narrow the rear or get another housing? [Re: scratchnfotraction] #1311152
09/26/12 07:24 PM
09/26/12 07:24 PM
West Plains, MO
West Plains, MO
"He" is me Thanks for the input.
But "a little" narrower takes me right back to the 57" A-body housing width doesn't it? I need about 3-4" less than my 60"... and I already have BBP rims
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311153
09/26/12 07:34 PM
09/26/12 07:34 PM
dogdays Offline
dogdays  Offline
The A-body brake spacing is peculiar to A-bodies and doesn't interchange with all other Mopar rear brakes.
If you could find a big bolt pattern A-body rear that was complete, it'd work and probably be cheap, because it's probably going to be an 8.25. If you bite the bullet and get your axle narrowed, it'll cost but it'll be done.
Often times I spend more trying to cheap something together than it would cost just to buy what I need.
R.
Re: Narrow the rear or get another housing? [Re: dogdays] #1311154
09/26/12 07:46 PM
09/26/12 07:46 PM
RobX4406 Offline
RobX4406  Offline
It's going to be $500ish to shorten and get new axles.
You can't shorten the stock B body axles, unless you go very short.
Get your wheel and tire combo, put it under the car and get a total width measurement. Any good axle guy can get you the right width housing and axles to center the tires/wheels in your tubs.
An A body rear with BBP axles in it will move the rim in about 1" per side,total width about 57.9". If you have tons of room to the inside, that may not be enough.
Re: Narrow the rear or get another housing? [Re: scratchnfotraction] #1311155
09/26/12 08:55 PM
09/26/12 08:55 PM
West Plains, MO
West Plains, MO
Narrowing it is...
I have seen plenty of good things about Dr. Diff but the website says he's in Montana... and I'm in Missouri. Not exactly next door
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311156
09/27/12 03:42 AM
09/27/12 03:42 AM
See if you can buy, trade, steal or swap for a 1965 B body rear end, not from a station wagon though The 1965 B bodys are the narrowest B body housing with the standard 5x4.5 bolt patterns I think there right at one to one and a half inches narrower than the 1967 and later B bodys, not sure about 1966 B bodys, sorry
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311157
09/27/12 09:28 AM
09/27/12 09:28 AM
Narrowing it is...
from here in Florida,Montana & Missouri are out that way. no?
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311158
09/27/12 10:30 AM
09/27/12 10:30 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Is it just me or does 60 inches sound like a big C body rear thought A bodies were around 53"???
Re: Narrow the rear or get another housing? [Re: Dodgem] #1311159
09/27/12 10:48 AM
09/27/12 10:48 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
dont cut up the B body axle---you just cant readily find them--cut up a c-body or truck/van axle-and use the c-body brakes and backing plates too-----bob
Re: Narrow the rear or get another housing? [Re: Dodgem] #1311160
09/27/12 11:03 AM
09/27/12 11:03 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
My 67 Barracuda has axels shortened 2", mini tubbed. I have a friend who does everything hot rod (his business), springs under the frame rails. Moser shortened the axels. It was done around 2003. I found that a short cut ( geting it done cheaply )is the quickest way to a place you don't want to go. You will forget the cost in a while but, you will never forget lousy work.
Re: Narrow the rear or get another housing? [Re: Dodgem] #1311161
09/27/12 11:05 AM
09/27/12 11:05 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
from the archives:
8 3/4" rear end widths, drum-to-drum:
A BODY
'66-'72= 57 1/8"
B BODY
'62-'63= 58 1/2" (And '64 Max Wedge)
'64 = 60 7/8" (Exc.Max Wedge)
'65-'67= 59 1/2"
'68-'70= 60 1/8"
'71-'74= 63"
'71-'73 wagon= 64 3/8"
C BODY
'65-'69= 61.75"
'70-'71= 63.0" (Chrysler & Fury)
'70-'73= 64 3/8" (and '69 wagon)
IMPERIAL
'65-'66= 61 15/16"
'67-'69= 62 5/16"
'70-'71= 59 3/4"
'72-'73= 64 9/16"
E BODY
'70-'74= 61 5/8"
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311162
09/27/12 11:42 AM
09/27/12 11:42 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Call me silly, but wouldn't it be cheaper to simply get different wheels than to cut down or replace a housing and axles?
But, you are now making a '72 look more like an '02 with the extreme positive offset. Maybe getting anarrowed rear is the correct answer to maintaining a period look and the wheel width you want.
So, perhaps the interim answer is use a 8" cop car wheel until you get the bones to make a new axle set up.
Re: Narrow the rear or get another housing? [Re: TC@HP2] #1311163
09/27/12 12:26 PM
09/27/12 12:26 PM
West Plains, MO
West Plains, MO
No, you're not being silly, but the problem is that no usable tires will fit until I get it narrowed or get another rear... and the 8" backspacing on my 10" rims is the maximum possible. I suppose I could use a dually wheel but now I'm being silly
(Even with the stock skinnies on 5" rims, the sidewalls are only 1/2" from the inner fender lips)
Besides, I prefer the sleeper look of steel rims without that "deep-dish" Pro Street vibe. From the side, just how big the tires are will not be immediately obvious, and from behind... well, I'm already in front!
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311164
09/27/12 01:02 PM
09/27/12 01:02 PM
RobX4406 Offline
RobX4406  Offline
A 65-67 rear likely won't be short enough. It's only 5/8" total shorter than what you currently have.
Minitubbed/relocated spring you can put a 325/50/15 under a dart without much issue.
You can also figure out what length you need bolting them to your current rear and using some math.
Good luck
Re: Narrow the rear or get another housing? [Re: DrCharles] #1311165
09/27/12 01:16 PM
09/27/12 01:16 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
At the point you are at you might as well build a cheap Dana 60 using a truck housing and easy to find ebay /junkyard pieces like a power lok or even the easier to find trac lok and 8-3/4 housing ends or better yet big ford housing ends. It takes some planning a scrounging but it can be done cheaply.
