Re: good drill size to prime a big block
[Re: mickm]
#1311105
09/26/12 05:59 PM
09/26/12 05:59 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Can't imagine why a 3/8 wouldn't do the job unless it is just wore out. Good excuse to buy a good cordless tho . Something 18v or better. Kevin
[Re: Dodgem]
#1311107
09/26/12 06:13 PM
09/26/12 06:13 PM
Challenger 1
Cincinnati, Ohio
I used to do it with a 3/8 had them smoking a few times lately been using a 1/2 drill it's just right! :-)
Yes you need a 1/2" drill imo. Milwaukee to answer your question on what brand imo. If you own it you will use for something other than priming motors. Got to have a 1/2" drill as you go through life.
[Re: bobs66440]
#1311110
09/26/12 08:03 PM
09/26/12 08:03 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Milwaukee, 1/2 variable speed gear reduced..(like a Mopar starter). It will prime it, for a long time... Dont forget to rotate the engine while priming to get both rockers/ heads lubed... And ...hold on tight ! and run in reverse..
[Re: sthemi]
#1311111
09/26/12 08:35 PM
09/26/12 08:35 PM
Challenger 1
Cincinnati, Ohio
Just happen to have both of my Milwaukee 1/2" drills in the same place, don't happen often. Both drills easliy over 10 years old and the big one has honed many engines with a real sunnen hone which takes some big azz arms and a strong back. Then the drill get's so hot you can't can't hold it no more with heavy leather gloves on, many times and it still works like new.
[Re: Exit1965]
#1311113
09/26/12 11:38 PM
09/26/12 11:38 PM
RapidRobert
With it dot to dot (6/12 o'clock) #6 is on compression/with the timing marks at TDC I believe the pass head oils then back up 3/4 turn (270 deg) till #8 is firing (rotor under #8 cap terminal) & see if the dr head is oiling. Easier on you (& the drill) & wipes less goop off of the cam lobes
[Re: AndyF]
#1311115
09/26/12 11:51 PM
09/26/12 11:51 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
No need for a drill, just use a speed wrench and turn it by hand. You only need to spin the wrench a few times to build up the oil pressure.
God did not invent power tools so we could use manual tools! As tim says Ya need more power!
[Re: Cab_Burge]
#1311117
09/27/12 08:06 AM
09/27/12 08:06 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I use an old and I mean old Craftsman 1/2 that I got at a yard sale for 3 bucks probally 20 years ago.I tried 3/8s but they never had enough umph when the pressue built.I like to see a lot of oil flowing when I prime.Rocky
Chrysler Firepower
[Re: AndyF]
#1311118
09/27/12 08:58 AM
09/27/12 08:58 AM
Challenger 1
Cincinnati, Ohio
Tim Taylor the tool man said we are supposed to use power tools, arrrggh.
I do agree it can be done by hand but that would be more like work!
[Re: therocks]
#1311119
09/27/12 09:23 AM
09/27/12 09:23 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
I have one of these big old 1/2 Craftsman drills , it only spins at 600 rpm.
[Re: AndyF]
#1311120
09/27/12 12:16 PM
09/27/12 12:16 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
It takes less than a minute to prime with a speed handle.
[Re: 446acuda]
#1311121
09/27/12 01:07 PM
09/27/12 01:07 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
My dad had a couple of the aformentioned big 1/2 inch craftsman drills. It primed quite a few motors years back before finally passing.
I smoked my Dewalt 1/2 after priming 2 440s. Still works fine, but the batteries are toast.
Smoked my 1/2 Skil the other day on a sbc motor. The Skil doesnt have much umphh...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 446acuda]
#1311122
09/27/12 02:59 PM
09/27/12 02:59 PM
Posts: 4,179 California
mickm
California
ok, priming the pump i can understand. but i want to prime the engine. if it takes a good 1/2" drill to do this, then how can you possibly prime the engine by hand?
well, reasonably anyway. i'm sure it can be done, but it's probably better than a weeks workout at the gym!
