good drill size to prime a big block #1311104
09/26/12 05:49 PM
09/26/12 05:49 PM
California
mickm Offline OP
mickm  Offline OP
California
i have a small, old 3/8" drill, not enough to prime a big block.
any recommendations on size, amperage, etc... for drill that will handle this? time for a new one anyway, and priming a big block once in a while isn't the only thing i need it for!
Re: good drill size to prime a big block [Re: mickm] #1311105
09/26/12 05:59 PM
09/26/12 05:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Can't imagine why a 3/8 wouldn't do the job unless it is just wore out. Good excuse to buy a good cordless tho . Something 18v or better.
Kevin
Re: good drill size to prime a big block [Re: mickm] #1311106
09/26/12 06:03 PM
09/26/12 06:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used to do it with a 3/8 had them smoking a few times lately been using a 1/2 drill it's just right! :-)
Re: good drill size to prime a big block [Re: Dodgem] #1311107
09/26/12 06:13 PM
09/26/12 06:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes you need a 1/2" drill imo. Milwaukee to answer your question on what brand imo.
If you own it you will use for something other than priming motors. Got to have a 1/2" drill as you go through life.
Re: good drill size to prime a big block [Re: Challenger 1] #1311108
09/26/12 07:38 PM
09/26/12 07:38 PM
dogdays Offline
dogdays  Offline
Agreed. My only problem is there are many Milwaukee half-inch drills and I'd like to have one of each! One thing more, the 500 rpm version can snap your wrist if the bit catches. It's a two-hander!
R.
Re: good drill size to prime a big block [Re: dogdays] #1311109
09/26/12 07:57 PM
09/26/12 07:57 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Definitely a 1/2" drill...and a GOOD one. I used my cheapo and it took a while to get the oil up...she started smoking pretty good. Be prepared...
Re: good drill size to prime a big block [Re: bobs66440] #1311110
09/26/12 08:03 PM
09/26/12 08:03 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Milwaukee, 1/2 variable speed gear reduced..(like a Mopar starter).
It will prime it, for a long time... Dont forget to rotate the engine while priming to get both rockers/ heads lubed...
And ...hold on tight ! and run in reverse..
Re: good drill size to prime a big block [Re: sthemi] #1311111
09/26/12 08:35 PM
09/26/12 08:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
Just happen to have both of my Milwaukee 1/2" drills in the same place, don't happen often.
Both drills easliy over 10 years old and the big one has honed many engines with a real sunnen hone which takes some big azz arms and a strong back.
Then the drill get's so hot you can't can't hold it no more with heavy leather gloves on, many times and it still works like new.
Re: good drill size to prime a big block [Re: Challenger 1] #1311112
09/26/12 09:08 PM
09/26/12 09:08 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've done it several times with a Ryobi 18v cordless. I don't see why a 3/8" wouldn't do it unless it's a real wimp.
Re: good drill size to prime a big block [Re: Exit1965] #1311113
09/26/12 11:38 PM
09/26/12 11:38 PM
With it dot to dot (6/12 o'clock) #6 is on compression/with the timing marks at TDC I believe the pass head oils then back up 3/4 turn (270 deg) till #8 is firing (rotor under #8 cap terminal) & see if the dr head is oiling. Easier on you (& the drill) & wipes less goop off of the cam lobes
Re: good drill size to prime a big block [Re: mickm] #1311114
09/26/12 11:41 PM
09/26/12 11:41 PM
AndyF Online content
AndyF  Online Content
No need for a drill, just use a speed wrench and turn it by hand. You only need to spin the wrench a few times to build up the oil pressure.
Re: good drill size to prime a big block [Re: AndyF] #1311115
09/26/12 11:51 PM
09/26/12 11:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
God did not invent power tools so we could use manual tools! As tim says Ya need more power!
Re: good drill size to prime a big block [Re: Dodgem] #1311116
09/27/12 12:23 AM
09/27/12 12:23 AM
I use 5W20WT oil, it primes a lot easier than the heavier oils use to I agree on the 1/2 reversable
Re: good drill size to prime a big block [Re: Cab_Burge] #1311117
09/27/12 08:06 AM
09/27/12 08:06 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use an old and I mean old Craftsman 1/2 that I got at a yard sale for 3 bucks probally 20 years ago.I tried 3/8s but they never had enough umph when the pressue built.I like to see a lot of oil flowing when I prime.Rocky
Chrysler Firepower
Re: good drill size to prime a big block [Re: AndyF] #1311118
09/27/12 08:58 AM
09/27/12 08:58 AM
Cincinnati, Ohio
Cincinnati, Ohio
Tim Taylor the tool man said we are supposed to use power tools, arrrggh.
I do agree it can be done by hand but that would be more like work!
Re: good drill size to prime a big block [Re: therocks] #1311119
09/27/12 09:23 AM
09/27/12 09:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have one of these big old 1/2 Craftsman drills , it only spins at 600 rpm.
Re: good drill size to prime a big block [Re: AndyF] #1311120
09/27/12 12:16 PM
09/27/12 12:16 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
It takes less than a minute to prime with a speed handle.
Re: good drill size to prime a big block [Re: 446acuda] #1311121
09/27/12 01:07 PM
09/27/12 01:07 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My dad had a couple of the aformentioned big 1/2 inch craftsman drills. It primed quite a few motors years back before finally passing.
I smoked my Dewalt 1/2 after priming 2 440s. Still works fine, but the batteries are toast.
Smoked my 1/2 Skil the other day on a sbc motor. The Skil doesnt have much umphh...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: good drill size to prime a big block [Re: 446acuda] #1311122
09/27/12 02:59 PM
09/27/12 02:59 PM
California
mickm Offline OP
mickm  Offline OP
California
ok, priming the pump i can understand. but i want to prime the engine. if it takes a good 1/2" drill to do this, then how can you possibly prime the engine by hand?
well, reasonably anyway. i'm sure it can be done, but it's probably better than a weeks workout at the gym!
Re: good drill size to prime a big block [Re: mickm] #1311123
09/27/12 04:26 PM
09/27/12 04:26 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Try it and you will see that it doesn't take much effort to do it by hand with a speed handle..even with cold 20W-50 oil.
