that should be fine tire is 12" wide at the center section (widest part ) so on an 8 " rim 2" inside and outside of rim so 4.5 + 2" is 6.5 inches from the flat/face of your brake drum and on my GTX there was about 7 7.5 inches from there back to the spring you can measure that.
the 8" rims may suck the side wall thus the center section in a bit.
My old slicks had a 14" center section and 4.5 back space 10" so also 6.5 inches and I has fine on spring clearance.
You should be fine on the outer side with a 8 inch rim but measure 3.5 inches + 2 " = 5.5 inches out from drum mounting face.
