Page 2 of 3 1 2 3
Re: Broke the Car ,,,pics included [Re: pittsburghracer] #1310651
09/26/12 03:06 PM
09/26/12 03:06 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Yea greasy oil soaked bolts loc-tite fails don't ask. But the block has scars
Re: Broke the Car ,,,pics included [Re: JD Dart] #1310652
09/26/12 06:00 PM
09/26/12 06:00 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Thanks again everyone. Figured I would post it,,if it helps someone else,,,or at least remind people to check their bolts.
These were not ARP bolts,,,they were new though. I am going to get some ARP's for the install.
I like the inspection cover idea,,,not much room with the pan i run, dont think i could get one to fit,,but might take a look on the install,,i have a extra laying around,,, it's hard to hear any "noise" coming under the car,,,just a few drips of oil off the back of the pan,,was the only clue.
thanks again for all the posts....I'll get it fixed pretty quick i hope.
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310653
09/26/12 06:25 PM
09/26/12 06:25 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
I have found a lot people tighten the convert bolts until the engine turns over and stop,
I use a angle iron wedge between starter ring tooth and block plus tighten bolts to 65 ft lbs or a 15 inch wrench I made just for convert bolts. Over a 100 such jobs and no lose bolts
Re: Broke the Car ,,,pics included [Re: dodger mope] #1310654
09/26/12 07:44 PM
09/26/12 07:44 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Some ARP's, Red Loctite and a new flexplate and you're back in business
The pan rail didn't look too bad....should be an easy fix
Ron
Re: Broke the Car ,,,pics included [Re: hemi-itis] #1310655
09/26/12 08:04 PM
09/26/12 08:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ouch, but really it could have been a lot worse. Get ya some Lock-Tite and get'em snug. Is the oil pan leaking?
Coming soon!!!!
Re: Broke the Car ,,,pics included [Re: Mr.Yuck] #1310656
09/26/12 08:33 PM
09/26/12 08:33 PM
KENTUCKY
KENTUCKY
Pan looks to be leaking "just a bit" ( with the motor running, not with it off and sitting )
going to pull the pan to check it for sure....also going to "prime" the motor,,before i pull the pan,,so i can lay under the car and check for any areas of leakage while i have someone spin the oil pump with a priming shaft.
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310657
09/26/12 09:57 PM
09/26/12 09:57 PM
ill
dennismopar73 Offline
ill
Find some longer vert bolts, you will find that the ones you are using only go about half way thru??
Re: Broke the Car ,,,pics included [Re: dennismopar73] #1310658
09/27/12 09:15 PM
09/27/12 09:15 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
When I drop the new engine in this winter with a fresh clutch, I will make sure the block saver is in between the flywheel and bellhousing.
Is there such a thing for the automatic trans guys?
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Broke the Car ,,,pics included [Re: MR_P_BODY] #1310659
09/27/12 10:30 PM
09/27/12 10:30 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I tighten mine with a impact... I go through the starter
area when the starter isnt mounted yet... just a couple
of 3 hits or so... I had 1 bolt come loose when using
a wrench... never since using the impact
are you sayin you can get to all the tc bolts through the starter hole?
Re: Broke the Car ,,,pics included [Re: bonefish] #1310660
09/28/12 06:42 PM
09/28/12 06:42 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Well, I hope you can get it fixed with minimal losses.
Re: Broke the Car ,,,pics included [Re: HardcoreB] #1310661
09/28/12 10:36 PM
09/28/12 10:36 PM
near St Petersburg, FL
Lifsgrt Offline
Lifsgrt  Offline
Good catch Doug, glad it was no worse than it is!
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Broke the Car ,,,pics included [Re: dartman366] #1310662
09/29/12 12:23 AM
09/29/12 12:23 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Sorry to see that happen . Glad you`re on top of the repairs and it`s not too bad. Same thing happened to my tow vehicle when a welded on weight on the converter went for a walk after two years . B&M flex plate was the way to go for me maybe you too ! Built a lot beefier.
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310663
09/29/12 03:26 AM
09/29/12 03:26 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Just a thought, before you put it all back together you might check your crank endplay?
Re: Broke the Car ,,,pics included [Re: pittsburghracer] #1310664
03/02/13 05:14 PM
03/02/13 05:14 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
I hear this so many times on this site it makes me cringe. When I was still working loc-tite salesmen would come in and tell us about new products, old products, and how to use them. Here are a few does and dont's.
1. All bolts nuts and fasteners must be clean. Recommended procedure is to clean the bolt on a wire wheel, soak and clean them in an oil free cleaner like paint thinner, and blow dry.
2. After applying loc-tite torque nuts or bolts to proper spec.
3. NEVER EVER retorque nuts and bolts at a later date as you will only break the seal that the loc-tite made. visual inspection only.
With convertor bolts sometimes it requires stacking open end wrenches (wrench on wrench. cheater lever) to get the bolts to proper torque. He recommended 271 (red) as the proper loc-tite for this use.
4. If you don't know the history of the bolts that you are going to use "get new ones" they are not that expensive.
If your convertor bolts come loose after doing the above method you have other issues going on.(alignment,vibration, ect.)
REMEMBER loc-tite will not work on greasy oil soaked bolts.
Good-luck with your repairs and I hope all goes well.
This is a very good, often overlooked, point. For the chemical threadlocker to work properly, the joined parts must be clean.
Also, after installation, take some good touch-up paint (a silver Sharpie would probably work good too) and paint a line on the flexplate and bolt head so that you can tell if the bolt loosens.
Sorry to hear about your troubles Doug. Bobby had a similar experience with the Belvedere years ago. One of the bolt lugs welded to the converter decided to come loose in the burnout box. The bolt, still screwed into the lug, pulled through the hole in the flexplate from the centrifugal force. Although it sounds worse than your experience, the damage wasn't as bad.
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: Broke the Car ,,,pics included [Re: Ramcharger] #1310665
03/02/13 06:55 PM
03/02/13 06:55 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I had the same thing happen to my 1967 GTX. It was making a really bad noise I pulled over on the side of a pretty busy hiway and left the car. Got a ride home,went back to get it a little over a hour later it was gone.Have not seen the car since.That was in 1992.I had the car since I was 16 years old.Now I make sure the bolts are tight.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Broke the Car ,,,pics included [Re: bonefish] #1310666
03/02/13 10:35 PM
03/02/13 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure can.... deep impact 6 point socket right on my
CP impact... I have the flex and the conv painted
on one ear and one bolt hole so it lines up right..
I put one bole in finger tight then rotate it to
get all 4 in then hit it with the impact a couple
of short hits then turn it and so on
Re: Broke the Car ,,,pics included [Re: Ramcharger] #1310667
03/02/13 10:56 PM
03/02/13 10:56 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
for ANY adhesive to work properly the surfaces must be clean and oil free. sealants, locking compounds, epoxy etc. even the most exotic sticky stuff won't stick to dirt and oil.
a high volatility cleaner should be used to remove any traces of oil. brake cleaner (the good stuff outlawed in NJ and CA stuff), acetone or similar.
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310668
03/03/13 11:53 AM
03/03/13 11:53 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Sorry to hear of your troubles.
I heard funny noises on my hooptie twice, and when I checked - the bolts were tight but the flex plate was broken. The first time I just replaced the flex plate and went back to playing. Then it did it again. I finally figured it out. The heads of my crank bolts were too thick and rubbing on the front of the convertor - which in turn forced my flex plate into a very slight "cone" shape. Apparently it didn't appreciate this at all. I made the bolt heads even shorter and now have no more issues with it. I only had to remove .040" to make it happy.
Re: Broke the Car ,,,pics included [Re: Duner] #1310669
03/03/13 12:17 PM
03/03/13 12:17 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I had a problem a few years ago... I kept breaking/cracking flex plates until I found the problem, the bolts to hold the convertor to the flex plate were a little too long and were bottoming out before tightening thus leaving a tiny gap between the bolt head and the flex plate. We just shortened the bolts a thread or two, applied plenty of Loc-Tite and never had the problem again.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Broke the Car ,,,pics included [Re: 11secdart] #1310670
03/03/13 02:17 PM
03/03/13 02:17 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Just a thought (from personal experience), but are you sure the converter bolts are the culprit here, and not the converter itself. This is exactly what will happen when a converter balloons. If it did it during the run but then was quiet again when off the throttle, that would again make me be suspicious of the converter. If it was just the bolts, they would have rubbed before and after the run as well.
Hopefully its as simple as the bolts. But I'd think about having that converter checked out before I just re-threaded it and stuck it back in there.
Page 2 of 3 1 2 3
