Header wrap #1310451
09/25/12 05:23 PM
09/25/12 05:23 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello im wraping my headers in dei header wrop, and well its a long process anyway it says to use the stainless bands which suck.. could i use fidrglass resin to join the ends to keep them from backing off?
anyone try it?
Re: Header wrap [Re: Dakota_Don] #1310452
09/25/12 06:08 PM
09/25/12 06:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How are you going to keep everything tight while the resin dries ???
By yourself some thin stainless wire at any hardware store and wrap off the ends with it. It's neat and won't rust off. Use wire ties to temporarily hold things in place. In fact, you can leave the ties there and they'll just melt off.
What's the purpose of the wrap ... to hold in heat or keep temps in the engine compartment down? Whatever, on a street car wrap is pointless as the heat will eventually (quickly) soak through the wrap and you're right back at square one. Furthermore, from experience, the wrap will SIGNIFICANTLY shorten the life of the headers - not only does the wrap hold in moisture which will promote rusting, the higher temps will cause the headers to become brittle and crack.
Re: Header wrap [Re: Stanton] #1310453
09/25/12 06:59 PM
09/25/12 06:59 PM
Alton, IL
Alton, IL
awww good idea.. lol wire
Re: Header wrap [Re: Dakota_Don] #1310454
09/25/12 07:41 PM
09/25/12 07:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kinda goofy, but how about a worm-drive hose clamp?
Re: Header wrap [Re: Dakota_Don] #1310455
09/25/12 07:57 PM
09/25/12 07:57 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Wear eye protection when working overhead with that stuff. I got a piece imbedded in my eye and didn't know about it until the eye doctor saw it during an exam and removed it.
