Re: Where does the power come from for 4 spd reverse lights
[Re: RodStRace]
#1310420
09/25/12 03:10 PM
09/25/12 03:10 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
That White wire continues on the next page to the Radio Conn., half way down the right side. Also connected to this terminal is the Red-TR wire that goes lower on the page and back over to the first page. On the first page, the Red-TR wire goes to the end fuse in the fuse block. They are not labelled, but I'd guess that checking the fuses, especially the end on that might be marked Radio, would help!
[Re: RodStRace]
#1310421
09/25/12 03:52 PM
09/25/12 03:52 PM
RodStRace
Chino Valley
So, with key ON, you should have power at the fuse. You should also have a 2-pin Radio connector under the dash with one terminal having two wires, White and Red TR. It should have power with key on. You should also have power at the White wire at the switch down at the shifter or transmission. When the trans is in reverse, the switch should be closed, allowing power through to the Violet wire.
That Black wire that feeds the fuse comes from the ignition switch and also feeds the wiper switch. It should have power with the key ON or ACC.
Kind of cute how they tie the radio into the reverse lights. That way, you know something is wrong with the reverse lights. Same sort of thing they did with the cluster lights. No power to the headlights? No power to the cluster lights either!
BTW, there have been stories about wiring harnesses that are not all wired correctly. Hopefully, this will give you the info needed to trace the circuits properly.
[Re: RodStRace]
#1310422
09/25/12 05:29 PM
09/25/12 05:29 PM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
Thanks, I was able to trace down the problem(s). First, the bulkhead connector on the wiper harness that feeds the circuit was loose. I soldered the wire back in place and now when I jump the loop feed at the bulkhead, the lights work. However, when I plugged the reverse harness back in to the connector and now there are still no reverse lights. So, I went under the car, jumped the switch connection and the lights still worked. Time for a new switch!
