Re: XR2/P7 Combo
[Re: Dave W]
#1309969
09/25/12 07:46 AM
09/25/12 07:46 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
When I had the 833 stock, it was miserable. So I had liberty pro shift it. That helped until around 8800 and it sometimes still would not go into gear even with a Hurst v-gate. With the 833 it was streetable and was a blast on the street. Even with the low torque numbers in 4th gear you could punch it and once it would hit about 5800 it would roast the tires. So if you could find a manual that can handle the rpms and shift you'd have a sweet set up. Since I switched to the 904 it doesn't like the street so much with the 7000 stall converter.
Re: XR2/P7 Combo
[Re: Dave W]
#1309975
09/25/12 11:18 AM
09/25/12 11:18 AM
DemonDust
Menomonee Falls
What about regrinding an existing Nascar cam?
I don't think that cam will work with the LA block timing cover and gears...
