Guys,
I'm finally trying to get my 408 magnum with LA style front, fired up in my 93 Dakota and Im having a few problems. Im running a 5 pin chrome box with 4 prong ballast resistor. I believe I have everything wired correctly, since I basically made my own engine harness and spliced into the ign 1 & 2 to the fuse box. It cranks but no spark. If I jump battery form the starter relay to the positive on the coil I do have spark. The coil has propper voltage at both key positions (12v and 6v respectively). I'm thinking the new ballast resistor is bad. Probably pick one up tonight, but looking to see if I'm missing something obvious.
Thanks in advance
