Wiring AC/blower motor?? #1309434
09/23/12 07:36 PM
09/23/12 07:36 PM
New Berlin,Wi
Firepowerflyer Offline OP
New Berlin,Wi
Could someone tell me where you ground the blower motor on a 69 B body with ac.Also would like to know what the factory termial end looks like.
Joe
Re: Wiring AC/blower motor?? [Re: Firepowerflyer] #1309435
09/26/12 04:59 PM
09/26/12 04:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Not sure on 69, but my 70 Sport Satellite had the wire going to the wiper motor mounting bolt.
However, my replacement blower motor, does not have a long enough ground lead, so I used the evaporator bracket bolt to ground it.
Cheers
Mark
Re: Wiring AC/blower motor?? [Re: Firepowerflyer] #1309436
09/27/12 09:42 AM
09/27/12 09:42 AM
PA
BTTG Offline
BTTG  Offline
PA
There is a tapped hole in the firewall just to the right of the blower motor (towards the centerline of car if facing the motor from the front bumper). See attached picture. Blower motor in picture is original, but was painted black by a previous owner. that is also the original fastener under the ground as well. no head markings on it. interestingly, my original engine ground was also attached in this same firewall hole and not higher up right of the ballast as frequently seen (it is encased in the conduit as the insulation was failing badly). When i asked about whether the original engine ground on an AC car was beside the blower or the ballast no one had a strong opinion/evidence so i kept it where i found it (beside the blower). factory terminal end on the blower ground is full closed circle... again the motor in the picture and wiring are original from 69 b w/ AC
Re: Wiring AC/blower motor?? [Re: BTTG] #1309437
09/27/12 10:16 PM
09/27/12 10:16 PM
New Berlin,Wi
New Berlin,Wi
Thank you,that was what I was looking for.
