1968 - 1970 340 X heads #1309309
09/23/12 04:04 PM
09/23/12 04:04 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
I took a chance on a set of 340 x heads and when I had them tanked and fluxed they came up cracked. Since these are such hard to find heads is there anything I can do or should I toss them in the scrap metal trailer and keep on looking?
Another question is what does a set of adjustable lifters go for?
Re: 1968 - 1970 340 X heads [Re: DEMONIC] #1309310
09/23/12 04:08 PM
09/23/12 04:08 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
No such thing as adjustable lifters.
Re: 1968 - 1970 340 X heads [Re: DEMONIC] #1309311
09/23/12 04:12 PM
09/23/12 04:12 PM
foristell mo
serano Offline
serano  Offline
foristell mo
I don't know that they are so hard to find,but they are expensive.I have some if you are looking
Re: 1968 - 1970 340 X heads [Re: serano] #1309312
09/23/12 06:16 PM
09/23/12 06:16 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
What harm does that crack cause?
I mean if you look at magnum heads, most are cracked right there between the intake and exhaust valve and many are still being driven.
Re: 1968 - 1970 340 X heads [Re: 1BAD68] #1309313
09/23/12 06:43 PM
09/23/12 06:43 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
Sorry solid lifters
Let me know about the heads you have. [Email]demonick@cox.net [/Email]
That is just one of many cracks.
If you want these cracked ones to run I am only $100.00 into them.
Re: 1968 - 1970 340 X heads [Re: DEMONIC] #1309314
09/24/12 12:11 PM
09/24/12 12:11 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
btt
Re: 1968 - 1970 340 X heads [Re: DEMONIC] #1309315
09/24/12 06:49 PM
09/24/12 06:49 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Those cracks are fixable but you have to ask yourself just how much are you willing to spend ?
That could be ground out and welded or pinned and a new seat put in. Possible thread repair also.
MLR426
Re: 1968 - 1970 340 X heads [Re: MLR426] #1309316
09/24/12 06:58 PM
09/24/12 06:58 PM
dogdays Offline
dogdays  Offline
A crack that starts in the valve bowl and goes through the seat to the spark plug hole is dead. It's silly to think otherwise. But you probably knew that already.
They're 42+ year old castings that have been through thousands of heat/cool cycles plus look like they have had metal removed in the bowl area. They have exceeded their service life. There is no guarantee another one won't be the same.
That is why reusing old heads is a crapshoot. I hope you didn't have too much money invested.
R.
Re: 1968 - 1970 340 X heads [Re: dogdays] #1309317
09/25/12 01:16 AM
09/25/12 01:16 AM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
Yeah I kinda thought the same. I got $100.00 in the heads and $50.00 for the tank and flux.
I had to take the chance though.
Re: 1968 - 1970 340 X heads [Re: DEMONIC] #1309318
09/25/12 02:07 AM
09/25/12 02:07 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I had a set that had that same crack from every intake seat to every spark plug hole. I traded them to a machinist friend of mine. He fixed 'em and sold 'em. I couldn't afford the fix...
